Pocket GPS World :: View topic - Urgent help please tom tom 1 need for tonight
BONDENO
PostPosted: Fri Mar 09, 2007 5:04 pm    Post subject: Urgent help please tom tom 1 need for tonight Reply with quote
Hi Thanks for trying to help me out.Just switched tom tom 1 on the screen comes on reading memory card then i get just the tom tom screen with the 2 red hands,No map cant switch off either unless i reset,Gone for reset and reset pressing in for 10 seconds,Any ideas please
PostPosted: Fri Mar 09, 2007 5:08 pm    Post subject: Reply with quote
Reset for 30 seconds with a pin, then see what happens - how was the device when you last used it? and have you added anything to it (POI, software updates etc) - Mike
BONDENO
PostPosted: Fri Mar 09, 2007 5:24 pm    Post subject: Reply with quote
Hi Mike
Thanks for trying to help,Yes poi added but been fine since adding them over twelve months ago.Tried reset button loads of time 30 seconds plus.
Phil
RQ
PostPosted: Fri Mar 09, 2007 5:36 pm    Post subject: Reply with quote
Did you make a backup that you could use?
BONDENO
PostPosted: Fri Mar 09, 2007 5:44 pm    Post subject: Reply with quote
Just tring that mike will let u know
Privateer
PostPosted: Fri Mar 09, 2007 5:51 pm    Post subject: Reply with quote
If nothing else works, take out and then put back SD card whilst unit is switched off. Then switch unit on.
Robert.
Garmin Camper 770 LMT-D
BONDENO
PostPosted: Fri Mar 09, 2007 6:12 pm    Post subject: Reply with quote
H Guys
Just put back up on sd card all seems to be ok ,I hope its stays ok,
Thanks for your time time guys
Cheers :D
PostPosted: Fri Mar 09, 2007 11:28 pm    Post subject: Reply with quote
Brilliant. Well done for having a backup. First
Saves SO much aggro! Smile
theripper
PostPosted: Sat Mar 10, 2007 2:33 am    Post subject: Reply with quote
Hi Bondeno
Just had the same problem updating software on a friends ONE, seems that the problem was upgrading two jumps so to speak. Reinstalled the backup then did one upgrade at a time and everything was ok
theripper
