Pocket GPS World :: View topic - loading speedcames
loading speedcames
mikeuk46
PostPosted: Thu Mar 08, 2007 3:06 pm    Post subject: loading speedcames Reply with quote
hello,i have download the speedcams date on to my tomtom ONE Regional,it seem to be loaded but nothing on the tomtom and other poi,where have i missed!
tonys66
PostPosted: Thu Mar 08, 2007 3:24 pm    Post subject: Reply with quote
1) You now need to 'enable' the cameras on the TomTom so you can see them on the map. Select them in your POI categories by going to: 'Change Preferences' then 'Manage (or Maintain) POI' then 'Enable / Disable POI' (the exact wording will depend on your TomTom unit)
Select each POI in turn.
2) You now need to set up proximity warnings for each camera type by going to: ' Change Preferences' then 'Manage (or Maintain) POI' then 'Warn when near POI '
Select each POI in turn and choose the warning distance and the warning sound
Uncheck the "Warn only if POI is on route" box so that you still get alerts if you are not navigating
Repeat steps 1-2 until all POIs are set up to warn.
PostPosted: Thu Mar 08, 2007 4:09 pm    Post subject: Reply with quote
Personal preference...
Many people keep it ticked to avoid spurious alerts from cameras on nearby roads...
PostPosted: Thu Mar 08, 2007 6:05 pm    Post subject: Reply with quote
I do this. HOWEVER you need to know that when you do, you will not get any warnings at all unless you have set up a route - this is no problem to me because I do precisely that - I have it set to warn only when on route and I always set a route whenever I go out. Even for local places where I know the route like the back of my hand (I have a number of "Favourites" locally too, so I sometimes navigate to one of those to give myself a route of sorts - it recalculates the route every time I go "wrong"). Incidentally, you'll still get some spurious warnings for cameras off route - the Tom Tom software isn't perfect and sometimes decides to warn if a camera is within the warning distance as the crow flies, rather than just on route
mjandar
PostPosted: Fri Mar 09, 2007 8:16 am    Post subject: Reply with quote
DennisN, quite rightly, says above: -
"Incidentally, you'll still get some spurious warnings for cameras off route - the Tom Tom software isn't perfect and sometimes decides to warn if a camera is within the warning distance as the crow flies, rather than just on route"
I know this has been discussed before but can anyone explain to me how and why it SOMETIMES happens? And can it be corrected?
PostPosted: Fri Mar 09, 2007 8:44 am    Post subject: Reply with quote
I've never found an explanation or a cure. My nearest local mobile is a prime example - on one side of a dual carriageway approaching a roundabout it warns for two directions - the correct approach and the least likely of the wrong ones, but NOT all three wrong ones. And Gatso 1014@40 on A449 Junction 13 of M6 always shouts as I go past. Does my head in. Evil or Very Mad It doesn't happen on a dual carriageway where the next turn is outside the warn distance, but it does if there is a gap in the central barrier where you could possibly do an illegal U-turn to go back past the camera. The cure is probably to set your warning distance to 5 yards!! Confused I've heard it doesn't happen on some devices - Garmins or Navmen? which can take account of the camera heading detail.
22.064 (26 Jun 24)
