Dippy Regular Visitor
Posted: Sun Mar 04, 2007 8:23 pm Post subject: |
Yes, I did that, so I can have a different wav for each category.
I have a nice lady saying "Thirty miles an hour maximum please" and "Possible mobile camera ahead" etc, different for each type of camera. |
marlow05 Occasional Visitor
Posted: Mon Mar 05, 2007 8:09 pm Post subject: |
done it now and it works :D
My woman sounds hot and she says:
"Warning Gasto ahead, speed limit 30 miles an hour"
Got one for each speed and type ! there great  |
robot1000 Occasional Visitor
Posted: Wed Mar 14, 2007 10:40 pm Post subject: Is full 7 digit postcode search connected to version 1.06? |
It's been a while since my last post about a problem with 1.06
Can anyone who has downgraded from 1.06 to 1.05 tell me if you still have full 7 digit postcode search?
Because currently I am using 1.06 and it has full digit 7 postcode search and I'm not sure if this is connected to version 1.06 and I wouldn't like to loose that
Please can you let me know
Many Thanks
Robert |
jullef Occasional Visitor
Posted: Tue Apr 03, 2007 11:36 am Post subject: wav and bmp files |
Can´t get it to work, first I have 3 files "gatso.bmp" , "gatso.wav" and "gatso.asc" in the same dir on my pc..
open the poi configurator and starts
Main catorgory name = gatso
Target system = navigonOEM
Map region = Europe
Cat name = gatso
Cat no = 1
ZoTx = 6
Asc file = ....\gatso.asc
ZoBM = 6
IV WAV = ....\.gatso.wav
converting
then I copy observer.obs to (poi observer) dir on the gps
and the gatso.bmp to bitmaps and the gatso.wav into sounds in the (poi observer) dir.
please help
get only the little red box that says Gatso and a beep when near a cam. |
Posted: Tue Apr 03, 2007 11:46 am Post subject: |
Nearly - you've done the hard bit.
Looks like you are putting a pathname into the congirator for the wav and the bmp, that matches the asc pathname?
That will fail - you actually have to put the pathname for the asc file, but then just a dot followed by the filename for the wav and bmp.
so you put something like this in the configurator:
c:\cameras\gatso.asc
.gatso.wav
That help? |
Posted: Tue Apr 03, 2007 11:53 am Post subject: |
thanks but only get a fail message when converting |
Posted: Tue Apr 03, 2007 12:12 pm Post subject: bmp and wav |
What am I doing wrong :-( |
Posted: Tue Apr 03, 2007 12:27 pm Post subject: |
thanks dippy just get it right with the wav -file
but can´t get the bmp to work (put the whole path in the bmp file) so I could convert it. |
Posted: Tue Apr 03, 2007 12:48 pm Post subject: |
POut the bmp and wav into the same directory as the configurator on your PC when you run the convert, so it doesn't need a pathname, from memory. Long time since I did this and I don't have access to a satnav at the moment! |
Posted: Tue Apr 03, 2007 3:05 pm Post subject: |
Thanks Dippy
thats the way to do it :-)
to bad
I think I have to do all that again
after updated the new map that suppose to be at sony site tomorrow
tx again |
greevessc Occasional Visitor
Posted: Sun May 13, 2007 8:55 pm Post subject: |
For interest.
I have just upgraded the UK map from Sony(NV-U50G). to do this you have to install new software. this changes the software to version 1.50.02. this version of software wwhen run with the virtual com program will not find the GPS on com port 0.
You cannot get the POI dtatbase to coexist.
If you revert back to software version 1.05 you cannot load the new map.
I had this problem previously with software version 1.06where version 1.06 does not work with the virtual com software. I doengraded to version 1.05 and all works fine except that you loose the upgraded postcode entry.
It would appear that if you want the new map updates you cannot install the POI speed camera database.
Anyone any ideas? |
chris13 Occasional Visitor
Posted: Fri May 25, 2007 12:42 pm Post subject: Installing POIObserver on a U71T ? |
Hi all,
Anyone who knows if I can install POIObserver on a NV-U71T ?
If it fails can I just re-install the unit from the CD/DVD ?
regards
Chirstian Birch Islev-Andresen
Sony NV-U71T |
Posted: Fri May 25, 2007 3:35 pm Post subject: |
I don't think you can I'm afraid, although I'm prepared to be corrected.
I think your choice is either to use POI-Warner, which may well work a lot more easily (but you have to pay a little for it) or wait until Sony get their act together and get their camera add-on available (don't hold your breath).
Actually, I'm not even sure POI-Warner works with it, but you can find them here:
http://www.navigating.de/cms/index.php?id=565 |
Benny5 Occasional Visitor
Posted: Tue May 29, 2007 8:25 am Post subject: |
Dippy wrote: | I don't think you can I'm afraid, although I'm prepared to be corrected.
I have no use for the camera POI's, most cameras in DK is mobile and I don't drive that fast anyway.
I need POI's for shops, etc. Usefull POI's, and the ability to make my own easy.
POI Warner doesn't run on 71t. I have asked them. |
