swebb Regular Visitor
Posted: Mon Mar 05, 2007 2:41 pm Post subject: Where have my speed cameras gone? |
I've just updated my 510 to 6. I have then downloaded the latest speedcameras from this site and copied them onto the unit, as per usual. However, I can't find any speedcameras in POI at all. I can see all other POIs no problem.
I have redownloaded them and reset the unit, but still no joy. Any ideas anyone?
cheers. |
Posted: Mon Mar 05, 2007 2:42 pm Post subject: |
The update should say 6.524. |
Posted: Mon Mar 05, 2007 2:45 pm Post subject: |
To add, you can see th e POI when using TT Home on the PC (368kb). So it's all there, just no visible on the unit for some reason.
Should I perhaps go back to 6.522? |
Posted: Mon Mar 05, 2007 2:47 pm Post subject: |
How many POI files have you got installed on the device? - count up the number of POI's - if you have more than 100 Custom POI's thats your reason, you need to reduce the installed custom POI's to less than the limit - Mike |
Posted: Mon Mar 05, 2007 2:51 pm Post subject: |
That may be possible then. I downloaded a load from here a short while a go.
I also can't find any police stations that I have as a POI (didn't find any ehwn searching for po (for the speed cameras)).
I'll delete some and see what I get.
cheers. |
Posted: Mon Mar 05, 2007 2:55 pm Post subject: |
Conect the device to the PC, start Windows Explorer and open the map folder, make sure that in Tools/ Folder options _ View Tab the "Hide Extensions for known file types" is NOT selected, now if you sort by file type you can very quickly see how many ov2 (the POI files) there are installed - Mike |
Posted: Mon Mar 05, 2007 3:17 pm Post subject: |
That's it - over 100. Have deleted some and now I can see the speed cmaers.
Many thanks Mike. |
Andy_P Pocket GPS Moderator
Posted: Mon Mar 05, 2007 3:36 pm Post subject: |
Don't forget you can merge two or more POI files into one big one (so instead of individual "Homebase", "Wickes", "B+Q" etc categories, you merge them into a single "DIY" category for example).
There are several utilities around that will let you do this...
POI Edit is just one. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15240 Location: Bradford, West Yorkshire
Posted: Mon Mar 05, 2007 3:59 pm Post subject: |
Andy_P2002 wrote: | Don't forget you can merge two or more POI files into one big one (so instead of individual "Homebase", "Wickes", "B+Q" etc categories, you merge them into a single "DIY" category for example).
or you can choose those from the PGPSW poi download area and get them merged as you download them ;)
MaFt |
Posted: Mon Mar 05, 2007 11:10 pm Post subject: |
Thanks for the tip guys. |
robertsnj2004 Occasional Visitor
Posted: Wed Mar 14, 2007 8:21 pm Post subject: POIs for speed cameras |
Following with interest the debate about seeing cameras. I have just updated to latest version of the OS and also downloaded Home. Home seems to have interfered somewhere - alongside the the Western_Europe_Map folder appears one called Western Europe, and only by dropping OV2 and associated BMPs into the latter can I see them on the device: contrary to previous experience (and formal advice). Anyone else experienced similar? |
RQ Regular Visitor
Posted: Wed Mar 14, 2007 10:34 pm Post subject: |
I haven't experienced the same problem but it may depend on which map you have selected. It reads like you have 2 map folders and it is the latter folder's map that is currently selcted. Hence, it is why the cameras only appear to work when located in that folder. |
thebinman Banned
Posted: Thu Mar 15, 2007 10:42 am Post subject: |
RQ wrote: | I haven't experienced the same problem but it may depend on which map you have selected. It reads like you have 2 map folders and it is the latter folder's map that is currently selcted. Hence, it is why the cameras only appear to work when located in that folder. |
If you have more than one map folder the speed cams need to be in both. |
Posted: Thu Mar 15, 2007 8:27 pm Post subject: POIs wrongly located |
My thanks for both the preceding replies - clarified for me the need to delete a spurious folder created by Home (which seems a little less than robust on downloads, etc). |
