Pocket GPS World :: View topic - Where have my speed cameras gone?
swebb
PostPosted: Mon Mar 05, 2007 2:41 pm    Post subject: Where have my speed cameras gone? Reply with quote
I've just updated my 510 to 6. I have then downloaded the latest speedcameras from this site and copied them onto the unit, as per usual. However, I can't find any speedcameras in POI at all. I can see all other POIs no problem.
I have redownloaded them and reset the unit, but still no joy. Any ideas anyone?
cheers.
swebb
PostPosted: Mon Mar 05, 2007 2:42 pm    Post subject: Reply with quote
The update should say 6.524.
swebb
PostPosted: Mon Mar 05, 2007 2:45 pm    Post subject: Reply with quote
To add, you can see th e POI when using TT Home on the PC (368kb). So it's all there, just no visible on the unit for some reason.
Should I perhaps go back to 6.522?
PostPosted: Mon Mar 05, 2007 2:47 pm    Post subject: Reply with quote
How many POI files have you got installed on the device? - count up the number of POI's - if you have more than 100 Custom POI's thats your reason, you need to reduce the installed custom POI's to less than the limit - Mike
swebb
PostPosted: Mon Mar 05, 2007 2:51 pm    Post subject: Reply with quote
That may be possible then. I downloaded a load from here a short while a go.
I also can't find any police stations that I have as a POI (didn't find any ehwn searching for po (for the speed cameras)).
I'll delete some and see what I get.
cheers.
PostPosted: Mon Mar 05, 2007 2:55 pm    Post subject: Reply with quote
Conect the device to the PC, start Windows Explorer and open the map folder, make sure that in Tools/ Folder options _ View Tab the "Hide Extensions for known file types" is NOT selected, now if you sort by file type you can very quickly see how many ov2 (the POI files) there are installed - Mike
swebb
PostPosted: Mon Mar 05, 2007 3:17 pm    Post subject: Reply with quote
That's it - over 100. Have deleted some and now I can see the speed cmaers.
Many thanks Mike.
PostPosted: Mon Mar 05, 2007 3:36 pm    Post subject: Reply with quote
Don't forget you can merge two or more POI files into one big one (so instead of individual "Homebase", "Wickes", "B+Q" etc categories, you merge them into a single "DIY" category for example).
There are several utilities around that will let you do this...
POI Edit is just one.
PostPosted: Mon Mar 05, 2007 3:59 pm    Post subject: Reply with quote
or you can choose those from the PGPSW poi download area and get them merged as you download them ;)
swebb
PostPosted: Mon Mar 05, 2007 11:10 pm    Post subject: Reply with quote
Thanks for the tip guys.
robertsnj2004
PostPosted: Wed Mar 14, 2007 8:21 pm    Post subject: POIs for speed cameras Reply with quote
Following with interest the debate about seeing cameras. I have just updated to latest version of the OS and also downloaded Home. Home seems to have interfered somewhere - alongside the the Western_Europe_Map folder appears one called Western Europe, and only by dropping OV2 and associated BMPs into the latter can I see them on the device: contrary to previous experience (and formal advice). Anyone else experienced similar?
RQ
PostPosted: Wed Mar 14, 2007 10:34 pm    Post subject: Reply with quote
I haven't experienced the same problem but it may depend on which map you have selected. It reads like you have 2 map folders and it is the latter folder's map that is currently selcted. Hence, it is why the cameras only appear to work when located in that folder.
thebinman
Banned
PostPosted: Thu Mar 15, 2007 10:42 am    Post subject: Reply with quote
If you have more than one map folder the speed cams need to be in both.
robertsnj2004
PostPosted: Thu Mar 15, 2007 8:27 pm    Post subject: POIs wrongly located Reply with quote
My thanks for both the preceding replies - clarified for me the need to delete a spurious folder created by Home (which seems a little less than robust on downloads, etc).
22.101 (03 Oct 24)
