Steve_o Occasional Visitor
Posted: Mon Feb 23, 2004 1:52 pm Post subject: |
Hi.
Anyone had any issues thier Pocket pc trying to connect to something. Scince installing the postcode software(not that i'm blaming it) I keep getting a window pop up every 20 mins or so saying "Unable to connect: You have no modem entries created,and no network card present"
My options are to dissmis or go into settings where I don't really know what i'm doing and don't want to start fiddling with with stuff.
Any idea's??
Thanks.
Steve_o |
stuartm Lifetime Member
Joined: 21/03/2003 10:37:20 Posts: 116 Location: Barkham
Posted: Mon Feb 23, 2004 3:31 pm Post subject: |
I've tried it and get the error message "Cannot find 'ukpostcode' (or one of it's components)" |
dynamite Occasional Visitor
Joined: Feb 09, 2004 Posts: 45 Location: Cambridge, UK
Posted: Mon Feb 23, 2004 8:23 pm Post subject: |
Stuartm,
If you give us a bit more info about what you're running (PPC2002 or WM2003 and on which machine) we may be able to figure out the problem.
A couple of other people have had that same error, and I'm sure we'll be able to fix it for you too.
As an aside, I've got a PPC2002 version compiled and running on one machine so far, it will be released to the web site over the next few days.
- Niels |
pgchimp Occasional Visitor
Joined: Jan 30, 2004 Posts: 59 Location: telford Shropshire
Posted: Mon Feb 23, 2004 11:59 pm Post subject: Note of thanks |
I feel that i ought to write a few lines offering a note of thanks for this programme and all the help Dynamite has offered to get this up and running
I am using an Ipaq 3950 with 2002 installed, I tried to load this programme without .NET installed but it was a "No Go"
After following the link supplied by Dynamite on this thread i installed the .NET software and using the programme for 2002 thought i would have a go.
Initally i got into a right mess and nothing worked, but this was due to my lack of knowledge understanding the link between the PC and the PPC
After i had got my head around this and restarted all went well, with the transfer via the activesync going to plan.
In operation throughout the day the programme was very responsive and rapid and a valuable asset to my work. I experienced no "lock ups" delays or any adverse workings within Tom Tom
So if you are running 2002 and need a brilliant post code data base which does not take forever then this is the one to try. It worked for me
pgchimp |
thax1 Occasional Visitor
Posted: Tue Feb 24, 2004 9:50 am Post subject: Steve_o |
Steve_o,
I had a similar thing about a year ago, where the pda would keep trying to dial out every 20 mins or so via a bluetooth link on my mobile.
If I didnt have a modem link setup, I'd probably see the error message you have now.
I think it was because i'd interrupted an activesync session partway thru.
I let it resync fully via the usb lead and it was fine thereafter.
Hope it helps. |
Parky Regular Visitor
Joined: 25/05/2003 09:12:02 Posts: 247 Location: Bradford UK
Posted: Tue Feb 24, 2004 12:01 pm Post subject: |
I get exactly the same as Stuartm "Cannot find ukpostcode (or one of it's components)"
Running a HP 5450 under 2002, installed the .net compact framework as required.
It's a pity, I would have liked to try this program.
Alan |
Nick412 Regular Visitor
Posted: Tue Feb 24, 2004 1:39 pm Post subject: |
hi,
ive just downloaded this and i have a problem which im hoping someone can help me out with.
i have downloaded the ppc 2002 version & unzipped to a folder on my desktop pc
i have clicked setup - and it connects to the pda
the next screen is where i get a problem...it shows me the apps currently installed with ticks etc...but
it says space required for this app 0.0kb
space available 32mb etc
after i select default folder, and click ok nothing happens, and it doesnt look as though it has installed.
any help would be gr8
im on my dinner so fast assist would be appreciated.
Regards
Nick _________________ Dell Axim X5 400MHZ - 128 CF Card - 256 SD Card - Rikaline 6010 TTNV2 (UK+Europe) - Checkpoint 2.02 - PPC 2002
www.mobilephonegames.ws |
Posted: Tue Feb 24, 2004 2:09 pm Post subject: |
Parky, Stuartm,
It would be worth you checking that you've got the latest download - there was an issue with the application trying to link to debug dlls which most people don't have on their machines. I've separated out the downloads so you should be able to download just the .exe files without the biiig database file. http://www.digitools.co.uk/downloads/ukpostcode/download.php
Nick412,
I see you are using CheckPOInt - in this case I don't think you need to run the setup.exe file at all, it installs the tomtom drivers which should already be on your machine. Try just copying the .exe and .dat files to your storage card (Step 4 onwards in installation instructions).
You can verify that you already have the tomtom driver on your machine by looking for a file called TTNControl.ocx in the \Windows folder on the PocketPC.
- Niels |
Posted: Tue Feb 24, 2004 2:41 pm Post subject: |
Hi Dynamite,
BIG THANKS for this app, very useful and extremely easy to use.
I did as you suggested and all works fine
In later versions is there going to be some kind of add code option>? as my postal code (and that of a friends) doesnt seem to be in the database.
It would be good if the user could possibly add a post code this they do the poi`s etc.
anyway, im well impressed, and you never know tomtom maybe calling you soon for app integration in the next version etc if they do, remember us wont you.!
Regards
Posted: Tue Feb 24, 2004 7:35 pm Post subject: |
Dynamite,
Great, got the program up and running with the new link.
Well done on what is a great little program, I look forward to using it over the next few days,
Alan |
Posted: Tue Feb 24, 2004 7:48 pm Post subject: |
Just had a thought about this fantastic major developement !
I can see so many of us wanting to use this program, that I think that when you read this Dave, Darren, or any of the GPS team, the topic should be made a sticky, for all to keep referring back to.
Alan |
DinAlt Regular Visitor
Posted: Tue Feb 24, 2004 9:15 pm Post subject: |
Just a quick note,
Been using this since it Dynamite asked for a few beta testers - it seems to work perfectly (more reliably than tomTom2 at any rate ).
The one thing it does higlight is the gaps in the post code data base (telford etc.) that said I did a multi point 350 mile journey today and not once did I have to check an address - and such is the speed of the app that it is till faster to page out of Tomtom and start the codechecker than use tomtoms address look up - all in all a fantastic little utility !!
DinAlt |
Posted: Tue Feb 24, 2004 9:28 pm Post subject: |
Hi DinAlt
I have been using this for the last 2 days using 2002, like you i needed postcodes for Telford and Shrewsbury
Living and working around Telford and Shrewsbury i have had cause to use Dynamites programme extensively. During the past 2 days of running this programme i have input over 60 Telford and Shrewsbury post codes,
Some i have used, some from adverts, Yellow pages etc, So far there has only been 5 telford post codes that did not work within the database. All the Shrewsbury and surrounding areas tried worked.
I will continue to trial these areas extensively inputting codes for use and reference
Alan |
Posted: Tue Feb 24, 2004 10:37 pm Post subject: |
Not sure I can cope with all this praise - thanks guys!
Regarding the missing post codes, I have a plan... It involves using a mobile phone to connect to the internet to resolve the missing postcode. A web service on my site would do the lookup so the PocketPC would only need to send and receive a short burst of data, making it quick and cheap to use (minimal phone charges).
It would take a little while to develop, but I think it can be done. Clearly only useful for people with internet connected 'phones.
Comments, suggestions...
- Niels |
Howarduk Pocket GPS Verifier
Posted: Wed Feb 25, 2004 3:30 am Post subject: |
In regard to the missing postcodes. I have read somewhere on this forum that there are one and half million postcodes in the UK. Now I think dynamites programme is absolutely brilliant and is the missing piece of software that TTN should have as part of its software
However, what he has done was use the existing postcode database from George Spanellis I havent actually counted all the postcodes that there is but I dont think its anything like one and half million. So, great idea about using the phone to get the missing postcodes, but possibly not very practical. However, if its the only way to get the missing postcodes then why not.
Howard |
