Pocket GPS World :: View topic - New way to do custom POI warnings in TomTom 5 & 6
Goto page Previous  1, 2, 3 ... 23, 24, 25 ... 33, 34, 35  Next
SpikeyMikey
PostPosted: Fri Mar 02, 2007 12:04 pm    Post subject: Reply with quote
I've visited this thread a few times and thought about having the voice alerts but I must admit I was put off by thinking that it was too much trouble.
I can honestly say that having now taken the plunge it took all of 15 minutes to download and reconfigure the warnings on the setup below.
Congratulations and thanks to all of you have been involved in the development and debate. I now have more confidence to maybe try other improvements.
Spikey
Mike
wombleuk
PostPosted: Fri Mar 02, 2007 8:57 pm    Post subject: Reply with quote
just caught up with this thread.
After reading every page, I guess that no-one has got this to work with TT Mobile yet?
PostPosted: Fri Mar 02, 2007 9:32 pm    Post subject: Reply with quote
wombleuk wrote:
No as the .ogg option only works with v6. TT mobile is v5, sorry Sad
mccw
PostPosted: Sat Mar 03, 2007 10:57 am    Post subject: Reply with quote
I have a ttone v 6.560. I understand I dont have to change the datachk file anymore but can not find the file witht the sounds so i can have voice alerts when nearing cameras. I have read this thread but think i might have the wrong idea of whats required. If anyone can help that would be great.
PostPosted: Sat Mar 03, 2007 11:01 am    Post subject: Reply with quote
Have you looked HERE?
Also have a look at the FAQs Page.
mccw
PostPosted: Sat Mar 03, 2007 11:10 am    Post subject: Reply with quote
I have read thru this 3 times now and just dont get it. I am usually very good with this sort of this. I can seem to find the voices for 6.560. do i have to download software and make the alerts myself? I upgraded my tomtom recently and the sounds were removed and now I just dont understand it. I have checked the sites and it just takes me round and round.....
please help
PostPosted: Sat Mar 03, 2007 12:23 pm    Post subject: Reply with quote
mccw wrote:
I have read thru this 3 times now and just dont get it....
Firstly check your e-mail account I have sent you some files that will help (I hope) - the old method used to involve a file called data.chk which you would swap for a modified one, this newer method is better as the warnings remain in place even when the software is upgraded, previously you had to change the data.chk file each time.
You can obtain the required ogg files from the links that are present on the page Richard pointed to above (or check your e-mail Wink . Mike
mccw
PostPosted: Sat Mar 03, 2007 12:56 pm    Post subject: Reply with quote
Thanks very much for this, i think i have got it working now, need to go for a drive to test it.
Great help
mccw
PostPosted: Sat Mar 03, 2007 12:58 pm    Post subject: Reply with quote
i think one problem was i had several different version of speed cameras installed as never knew whichof the 3 i had to use....think i should be ok but will post a response later today
PostPosted: Sat Mar 03, 2007 1:00 pm    Post subject: Reply with quote
You don't need to go out anywhere to test it, simply select Advanced Planning (AtoB) and set a depart point and destination point that you know passes a camera (or two) then use Route Demo set the speed to 100% sit back and watch/ listen - Mike
mccw
PostPosted: Sat Mar 03, 2007 1:14 pm    Post subject: Reply with quote
just did that and know i have 3 warnings going off for each camera. i think i have installed several different versions because i was never sure which one i needed, can you help as i want to delete the cameras and start again and just install the one file covering the latest cameras.
thanks in advance
PostPosted: Sat Mar 03, 2007 1:33 pm    Post subject: Reply with quote
Do a full back-up of your memory card see Here for details.
Delete the files that start with a file name of pocketgps_uk (their file extension will be .bmp and .ov2)
Download, unzip and install to your map folder the Speed Zoned file set - It is upto you if you want to use the pMobile files, if not simply delete them before copying to the device - Note there are no ogg audio files for the pMobile cameras in the folder I sent you - If you do install the pMobile cameras then you will still get an alert but you will have to select which "Sound" Bell 1 etc that you want for these cameras, all the others will have spoken alerts.
A full list of the POI files you need to go with the ogg files is:
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_specs_20.ov2
pocketgps_uk_specs_30.ov2
pocketgps_uk_specs_40.ov2
pocketgps_uk_specs_50.ov2
pocketgps_uk_specs_60.ov2
pocketgps_uk_specs_70.ov2
pocketgps_uk_specs_tba.ov2
pocketgps_uk_redlight.ov2
pocketgps_uk_temp.ov2
Once these files are on your device make sure the ogg files are also installed to the map folder and re-configure your warnings - then try a test route to see what it does - Mike
oldfogy
PostPosted: Sat Mar 03, 2007 10:44 pm    Post subject: Reply with quote
I find that providing you do not set a speed beyond 385% the warnings will still sound.
But to be on the safe side try around 350% first.
(If it ain't broke, I can soon fix it)
mccw
PostPosted: Sun Mar 04, 2007 12:13 pm    Post subject: Reply with quote
think i might have it now
thanks for the help
flt123
PostPosted: Sun Mar 04, 2007 2:28 pm    Post subject: cannot get .ogg to work Reply with quote
i have downloaded and renamed the liz .ogg file.i then put them into the western europe map folder with my speed camera files but when i go to "warn when neer poi" it still asks me to select a sound
i have used this before but had to do a hard reset and lost everything now i cannot get it to work any one got any sugestions please
Question
Page 24 of 35
