Pocket GPS World :: View topic - Tomtom 5 on IPaq No Maps Message - Help Needed
mattcity
PostPosted: Fri Mar 02, 2007 10:10 am    Post subject: Tomtom 5 on IPaq No Maps Message - Help Needed Reply with quote
Hi Sorry if this has been posted before, did a search and found nothing!
Using tomtom 5 on an Ipaq 2110 yesterday turned tomotom on and got "no maps found" mesage. I can see the current map and GB map files in the tomtom folder under my documents, but there is no map in th gb map folder on the SD card???????
Any help woudl be greatfully received
cheers
Matt
Greenglide
PostPosted: Fri Mar 02, 2007 1:37 pm    Post subject: Reply with quote
Is this a new installation of TomTom?
The map should be in a folder on the memory card as a series of files. If it did work but doesnt any more the file system on the card could be damaged or one or more files has been accidentally deleted.
mattcity
PostPosted: Fri Mar 02, 2007 2:08 pm    Post subject: Reply with quote
thanks for the reply, it has been working happily for a few weeks now and without doing anything on the PDA it just stoped finding the maps??
Did a journey for work sat in a meeting for 4 hours fired the PDA back up and no maps.
Tried re installing and still same problem.
Just rechecked and i have three maps in both the my docs folder on the pda memeory and the gb maps on the sd card in the gb maps folder.
It just wont recgonise the files.
Starts up with the green legal notice screen then goes to the select maps screen and says no maps and forces you to close the application.
any more help??????
Parky
PostPosted: Fri Mar 02, 2007 3:11 pm    Post subject: Reply with quote
I've had this a couple of times, it usually corrects itself if I remove the SD card (assuming you using SD) and simply re-inserting the card. Start up Tom Tom and everything is fine. May be worth giving it a go.
Alan
Mio P550 Mio 3 TTN 6 2GB SD Card, Ipaq 5450: Integral 1Gb SD card, TTN 6, POICapture, PPC 2003
23.013 (15 Jan 25)
