Pocket GPS World :: View topic - roadmate 300
roadmate 300
slohand
PostPosted: Thu Jan 04, 2007 9:23 pm    Post subject: roadmate 300 Reply with quote
hello anyone, i am an unfortunate rm 300 owner, after formatting internal memory as a mistake, then it says mapnot found. Does anyone know if it is possible fix the unit by user and not shpping it in usa to magellan?
thank you in advance
efparri
PostPosted: Mon Feb 12, 2007 1:06 am    Post subject: Reply with quote
The basemaps are on the RoadMate Manager CDs. You can copy them to the SD card and it will work the same as basemaps in the internal memory. You can also copy the sound files from the Languages folder to the RoadMate internal memory. You will have to get the Index.WTC file from Magellan if you get the Unauthorized Unit error with RoadMate Manager. You can still use the device but you cannot setup the unit with the software or load maps into internal memory with RoadMate Manager.
slohand
PostPosted: Fri Mar 02, 2007 10:48 am    Post subject: Reply with quote
Hello i am looking for map of france on roadmate magellan i share italy map and south alps with switzerland thank you. Also i need the CD manager because italian version does'nt have it thank you all bye guyz
