mattcity Occasional Visitor
Posted: Fri Mar 02, 2007 10:10 am Post subject: Tomtom 5 on IPaq No Maps Message - Help Needed |
Hi Sorry if this has been posted before, did a search and found nothing!
Using tomtom 5 on an Ipaq 2110 yesterday turned tomotom on and got "no maps found" mesage. I can see the current map and GB map files in the tomtom folder under my documents, but there is no map in th gb map folder on the SD card???????
Any help woudl be greatfully received
cheers
Matt |
Greenglide Lifetime Member
Joined: Apr 04, 2006 Posts: 295 Location: South East Northumberland, UK
Posted: Fri Mar 02, 2007 1:37 pm Post subject: |
Is this a new installation of TomTom?
The map should be in a folder on the memory card as a series of files. If it did work but doesnt any more the file system on the card could be damaged or one or more files has been accidentally deleted. |
Posted: Fri Mar 02, 2007 2:08 pm Post subject: |
thanks for the reply, it has been working happily for a few weeks now and without doing anything on the PDA it just stoped finding the maps??
Did a journey for work sat in a meeting for 4 hours fired the PDA back up and no maps.
Tried re installing and still same problem.
Just rechecked and i have three maps in both the my docs folder on the pda memeory and the gb maps on the sd card in the gb maps folder.
It just wont recgonise the files.
Starts up with the green legal notice screen then goes to the select maps screen and says no maps and forces you to close the application.
any more help?????? |
Parky Regular Visitor
Joined: 25/05/2003 09:12:02 Posts: 247 Location: Bradford UK
Posted: Fri Mar 02, 2007 3:11 pm Post subject: |
I've had this a couple of times, it usually corrects itself if I remove the SD card (assuming you using SD) and simply re-inserting the card. Start up Tom Tom and everything is fine. May be worth giving it a go.
Alan _________________ Mio P550 Mio 3 TTN 6 2GB SD Card, Ipaq 5450: Integral 1Gb SD card, TTN 6, POICapture, PPC 2003 |
