Pocket GPS World :: View topic - Memory Map on MIO P350
Enjay
PostPosted: Wed Aug 09, 2006 11:41 am    Post subject: Memory Map on MIO P350 Reply with quote
Is anyone using Memory Map Pocket Navigator successfully on a MIO P350?
If so, what settings are you using? I had the trial version running fine, but since installing a registered version I can't get the satellite strength to display and it won't lock to satellites at all sometimes - it just 'locks' to the last position I was using (whichg could be several days ago).
I am follwoing this up with MM but so far none of their suggestions are working. One problem seems to be that Manufacturer should the NMEA and model set to "N/A". However the model just displays NMEA0183 RMC and I can't change it.
Any suggestions welcome!
righty
PostPosted: Thu Mar 01, 2007 10:38 am    Post subject: MEMORY MAP PROBLEM MIO P350 Reply with quote
Enjay
I got a mIO P550 AND IT WORKS FINE AND MY MATE HAS GOT P350 AND WORKS FINE.
TRY TO INSTALL MEMORY MAP AGAIN BUT MAKE SURE YOU UNINSTALL FIRST. INSTALL ON PC FIRST AND PUT YOUR KEY IN TO MAKE IT GENIUE COPY. THEN INSTALL ON PDA. TRY INSTALLING ON THE SD CARDS INSTEAD OF THE MAIN PDA AS WELL
IT MIGHT BE THAT THERE IS SOMTHING WRONG WITH YOUR GPS AS IT SHOULD SAY NMEA GPS TO CHOOSE.
IF WANT ANY MORE HELP PLEASE GET BACK TO ME.
THANK YOU
RIGHTY Smile 8)
Enjay
PostPosted: Fri Mar 02, 2007 10:04 am    Post subject: Reply with quote
Thanks - I have now resolved the issue by uninstalling, hard-rebooting and re-installing. Works fine now!
enjay
22.062 (12 Jun 24)
