Pocket GPS World :: View topic - postcode search
postcode search
madasaman
PostPosted: Thu Mar 01, 2007 3:31 pm    Post subject: postcode search Reply with quote
how do i get the post code search to work in my french map? upgraded to map V6 and it doesn't work any more.
Ipaq 2215
tomtom 5.21
map V6
PostPosted: Thu Mar 01, 2007 4:08 pm    Post subject: Reply with quote
If it is a France only Map then the Postcodes for UK won't work.
If you mean that you can't use a French Postcode Search in France, it's because they don't use Postcodes as we know them in the UK. Smile They do have area codes though.
Perhaps you could be a bit more specific with your query.
madasaman
PostPosted: Thu Mar 01, 2007 4:39 pm    Post subject: Reply with quote
sorry its the area codes as in 34300. i can add a favourite if i know the address but cant use the area code in the post code window
madasaman
PostPosted: Thu Mar 01, 2007 4:49 pm    Post subject: Reply with quote
before i upgraded to V6 i could use the "postcode feature" in my french map as in the area code then search through the roads to find the place i wanted. Now if i put in the area code i get somewhere in the UK?
PostPosted: Thu Mar 01, 2007 7:11 pm    Post subject: Reply with quote
If you use Address | Street and House Number and then input the 34300 it will offer areas to which you can then add Street Names.
madasaman
PostPosted: Fri Mar 02, 2007 8:28 am    Post subject: Reply with quote
if i use address, the first screen to show is city, and there is no way to bypass this to input street and number then area code.
On my V5 map if i used postcode i could input the area code and the various towns in the area this related to came up, then the street, house number etc could be picked. Not so with this V6 map.
PostPosted: Fri Mar 02, 2007 2:35 pm    Post subject: Reply with quote
On my Map if I put in 34300, I'm offered Agde. If I select it then I can put in the Street. The first offered is Allee Bella Vista.
Is that happening with yours? Confused
madasaman
PostPosted: Fri Mar 02, 2007 6:56 pm    Post subject: Reply with quote
no when i put in 34300 i get union street aberdeen?????
PostPosted: Fri Mar 02, 2007 7:03 pm    Post subject: Reply with quote
Confused
Do you have the France Plus Map?
Although it shouldn't make any difference, as 34300 is not a valid reference to anything in Aberdeen.
madasaman
PostPosted: Fri Mar 02, 2007 7:26 pm    Post subject: Reply with quote
got france plus map v660, tried reinstall but get the same.
madasaman
PostPosted: Fri Mar 02, 2007 7:32 pm    Post subject: Reply with quote
when i go to post code, i get the window but with english places under where you input the post/area code Question think i'll try installing map on another card without the gb plus map and try post code again
madasaman
PostPosted: Fri Mar 02, 2007 8:29 pm    Post subject: Reply with quote
Ok put france plus map on another card on its own and the post/area code works Question but if i use a card with GB plus and France plus it doesn't
PostPosted: Fri Mar 02, 2007 10:09 pm    Post subject: Reply with quote
I'm assuming you changed to the France Plus Map!?
If the France Map, on it's own Card works OK, then it should work OK when both Maps are on the same Card.
The TT only looks in one Map Folder at any one time. Confused
madasaman
PostPosted: Sat Mar 03, 2007 1:34 am    Post subject: Reply with quote
Well I thought so as well, but it wasn't working. Will format disc tomorrow and reinstall both maps, putting france plus on first and see if that works. Just back from the local and too tired (sic) to try now. Guudnight. Laughing Out Loud
madasaman
PostPosted: Sat Mar 03, 2007 8:38 am    Post subject: Reply with quote
well tried uninstalling and reinstalling everything but got the same issue, then i tried putting the postal zip folder into the GB plus folder and hey the france post/area code works and so does the GB post code. Didn't have to do that with the previous maps. But hey if it works huh. think this post can be closed, and thanx for the help oldboy :D
23.084 (27 Aug 25)
