Pocket GPS World :: View topic - Help - ICN530 problem
timmot
PostPosted: Mon Feb 26, 2007 12:39 pm    Post subject: Help - ICN530 problem Reply with quote
I brought a ICN530 Nordic last November for a trip through Europe.
The unit worked fine until after I came back I deleted all the maps I don't need.
Now when I start the GPS the unit starts simulation routing on a road in the UK (maps are deleted!!), I have unchecked the simulation option, canceled the route, but after a few minutes it starts again !!
The only way to get around this is to set a new route (I live in Sweden), but after the route is complete the unit goes back to the route in the UK and the simulation option is checked again.
Is there anyway to do a hard reset which will return the system back to the original settings, I have used the stylus in the reset hole on the units bottom, and turned the power switch off and on - none of this helped.
Maybe I should reinstall the UK maps and then delete the route ?
I am off to Spain in a few weeks and would like to know the unit is working as it should.
Any tips would be helpful
Thanks !!
Krasimir
PostPosted: Mon Feb 26, 2007 7:37 pm    Post subject: Reply with quote
If you mean the small switch marked -o which turns the battery on/off then you have already done a "hard reset". There is no a "harder reset" unfortunately.
Sounds like something which could help. Good luck!
HP iPAQ rx5935 (no SD card, this one has 2GB NAND flash built-in)
timmot
PostPosted: Mon Feb 26, 2007 8:08 pm    Post subject: Sorted Reply with quote
Smile
I did a new hard reset, this time I left the unit off for a couple of minutes - seems to have done the trick, clicking the battery off and on probably didn't clear the memory - well, fingers crossed !
Gee-Pee
PostPosted: Tue Feb 27, 2007 10:59 am    Post subject: Re: Sorted Reply with quote
timmot wrote:
Smile
Let the forum know how you got on....this problem is on unique and your solution might help others. 8)
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
TheM
PostPosted: Tue Mar 06, 2007 10:52 pm    Post subject: Reply with quote
Make sure that all three demonstration checkboxes are unchecked -- Route Demonstration, Repeat and SmartST Demonstration.
From your descriptions sounds like you have SmartST Demonstration turned on -- that will pick up first two of your favourites and continuously demonstrate route between them.
