Pocket GPS World :: View topic - Cable Packard Bell 2030 to Garmin Etrex Venture GPS
Rich27
PostPosted: Thu Feb 19, 2004 10:25 pm    Post subject: Cable Packard Bell 2030 to Garmin Etrex Venture GPS Reply with quote
I am considering buying TOM TOM software for my Packard Bell Pocketgear 2030.
I already own a Garmin Etrex Venture GPS and have checked with TOM TOM that it will accept data from this device.
My question is "Where would I buy a cable that would connect the Garmin Etrex Venture GPS device to the Packard Bell Pocketgear 2030 and can you predict any problems from trying to attempt this?
I would appreciate any help.
Regards
Rich
PostPosted: Thu Feb 19, 2004 10:42 pm    Post subject: Reply with quote
Unless PC-Mobile have a suitable cable (Http://www.pc-mobile.com) then another option is an eTrex to Serial Cable, a Packard Bell Serial Cable and a null modem adapter to connect the two leads.
Assuming you can source the correct cable or use the above there should be no problem connecting the two, select NMEA out on your eTrex and COM1 NMEA on the PPC and you'll be up and running Thumbs Up
Pc-Mobile
PostPosted: Sun Feb 22, 2004 9:50 pm    Post subject: Reply with quote
If you look at the compatibility list at the bottom of the GPS cables pages you can see PB2030 use the same interface as Viewsonic V35.
So any one of the following is suitable depenidng on your requirement:
GEV35
GEV35P
GPEV35
Pc-Mobile
http://pc-mobile.net/gps.htm
22.063 (19 Jun 24)
