Pocket GPS World :: View topic - New way to do custom POI warnings in TomTom 5 & 6
Goto page Previous  1, 2, 3 ... 22, 23, 24 ... 33, 34, 35  Next
l11obs
PostPosted: Fri Feb 23, 2007 2:11 pm    Post subject: Reply with quote
Ah I have 2 map folders on the device, should I turn any warnings for that one off?
View user's profile Send private message Visit poster's website MSN Messenger
l11obs
PostPosted: Fri Feb 23, 2007 2:13 pm    Post subject: Reply with quote
Cancel that, they are switched off :D
How do I best work round this then?
PostPosted: Fri Feb 23, 2007 2:19 pm    Post subject: Reply with quote
As you have two map folders have you been putting the warnings into the correct map folder and is this map selected as the current active map? (Change Preferences/ Manage maps/ Switch Map) - then configure the warnings.
Each map will contain its own POI Warning set-up file so it is quite possible you have been putting the files in the wrong map? - or have you still got ov2 files from a previous install in the current map folder - but have been looking in the wrong map folder for the POI files - Mike
l11obs
PostPosted: Fri Feb 23, 2007 2:23 pm    Post subject: Reply with quote
I am 100% certain Ive been working in the right folder (GB only) and all old poi's have been removed only using the latest poi's downloaded from here. (speed defined) done it several times now with the same result.
l11obs
PostPosted: Fri Feb 23, 2007 3:47 pm    Post subject: Reply with quote
Thanks to mike and half hour or so on msn I'm sorted and as happy as a pig in *#*$ Bouncing Not Worthy Jumping With Joy Cheers Mike
PostPosted: Sat Feb 24, 2007 10:23 pm    Post subject: Reply with quote
Gonna tell us what sorted it then?
Please.... Smile
Madmouse
PostPosted: Sat Feb 24, 2007 10:25 pm    Post subject: Reply with quote
beat me to it...i'm puzzled as to how its been sorted please tell!! (although if a looooong msn session was involved i'm not so sure!) Laughing
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Sat Feb 24, 2007 10:26 pm    Post subject: Reply with quote
The only thing I could see wrong with any of the files etc was the ogg sample rate set to 16000Hz - once we put the correct files on the device at 22050Hz it worked no problem - Mike
Madmouse
PostPosted: Sat Feb 24, 2007 10:27 pm    Post subject: Reply with quote
cheers for that...strange thing was I did exactly the same myself but all is well now
thanks mike
PostPosted: Sat Feb 24, 2007 10:29 pm    Post subject: Reply with quote
30 mins is not long considering file transfer time and checking etc - then go though set-up and make sure the device is working correctly - Mike
Madmouse
PostPosted: Sat Feb 24, 2007 10:31 pm    Post subject: Reply with quote
fair point...we'd be lost without just glad to hear all is well now
badgerdid
PostPosted: Tue Feb 27, 2007 2:06 pm    Post subject: Reply with quote
Can you post the single file warning again, the links down for the download, thanks
I set the single file camera poi, warn when its near and choose the sound, some alarm, and then turn off the poi in enable disable poi. This then still warns me when i approach a camera, displays on the screen and the siren sounds. This is because i dont want it to display all the cameras all over the place etc.
Will this still work like this, with the modified method here?
PostPosted: Tue Feb 27, 2007 2:26 pm    Post subject: Reply with quote
Which one are you after?
If you PM me with your email address and which one you want (original PGPSW "computer" voice, Ray Flanagan's "Liz", TTS, etc.) I'll send it to you.
Yes it will still work if you set it up as per instructions
badgerdid
PostPosted: Tue Feb 27, 2007 2:57 pm    Post subject: Reply with quote
Mullet wrote:
..and while i'm at it.
For anyone using the PGPSW SINGLE FILE speed cameras, my modification of Ray Flanagans "LIZ WHITAKER" are below.
22050Hz file http://www.yourfilelink.com/get.php?fid=196268
16000Hz file http://www.yourfilelink.com/get.php?fid=196269
Edit once MikeAlder - As Requested!
Its this one im refering too, file not found
Mullet
PostPosted: Tue Feb 27, 2007 3:07 pm    Post subject: Reply with quote
deleted
Page 23 of 35
23.084 (27 Aug 25)
