Pocket GPS World :: View topic - TomTom TMC - Areas of Service / No Service
Goto page Previous  1, 2, 3 ... 13, 14, 15 ... 18, 19, 20  Next
tonygamble
PostPosted: Fri Feb 16, 2007 11:04 am    Post subject: Reply with quote
Report 4.
Installed the new version of the 910 software.
Not a jot of improvement to the TMC.
Spoke to TT this morning who are escalating my request for help to someone more experienced.
Sadly I realised that all the Help Desk are based in Holland and thus have no working experience of trying to get a signal from Classic FM. I remember as a youngster listening to Hilversum radio from Holland - and it was clearer than the BBC !!
Tony
Pritch
PostPosted: Fri Feb 16, 2007 8:06 pm    Post subject: Reply with quote
I thought I'd have a go at getting sense from the TomTom support and asked them about the signal quality. Here's the response:
"We suggest setting up your TomTom and TMC receiver outside your car. Do you receive a signal, does it lock on to a frequency?
it should show you which frequency you are locked onto in the traffic menu.
TMC broadcasts can vary in how often a signal is transmitted, it may take upto an hour to receive a signal or any data.
Please let us know if you are able to receive a signal outside the car."
OK, so apart from holding the TMC receiver outside the car, you have to wait an hour for a signal. Apart from my arm aching within that time, 1 hours wait is a bit too much for me!!
If I understand the previous posts correctly, a standard internal window antenna like I have in my Audi is powered and therefore could kill my TT if I connect the TMC to it?
I would therefore need to use a second antenna, like the Hirschmann one...having given up on TomTom recalling all their TMC receivers and replacing them with working devices...
manicminer
PostPosted: Mon Feb 19, 2007 9:59 pm    Post subject: Reply with quote
Hi I may have a solution for those people that require the tmc receiver to be used in more than one vehicle. I have completed the tmc receiver mod as earlier in the thread and than attached a uhf/vhf receivers see link below
http://cgi.ebay.com/UHF-VHF-FM-Small-Portable-Compact-Amplified-Aerial_W0QQitemZ140059826951QQihZ004QQcategoryZ73383QQcmdZViewItem
I have the uhf/vhf receiver mounted on Velcro pads, just above the rear view mirror. The cable then goes across the top of the windscreen and down the left-hand door pillar (all hidden) with the tmc receiver stuck to the bottom left hand corner of the screen- tmc cable runs at the back of the dash again all hidden. I am now getting vast improvement over just using a length of coax. I regularly travel between Barnsley and Birmingham and can now do the whole trip with a solid lock on classic fm
Hope this help
Manic
tonygamble
PostPosted: Tue Feb 20, 2007 9:21 am    Post subject: Reply with quote
Manic,
Did you try to see if that aerial worked if placed near the TT?
It would have saved that long cable run if it did.
I'm guessing that you found that it didn't - but feel compelled to ask!
Tony
Nixxrite
PostPosted: Tue Feb 20, 2007 6:24 pm    Post subject: Reply with quote
"it should show you which frequency you are locked onto in the traffic menu"
I'm assuming this is the TomTom Traffic menu? I also read elsewhere that you can re-tune the TMC?
Like most others here, this fails to work. Does anyone have screenshots showing this working and what I should expect to see on screen?
BTW, sorry if this information has already been posted but I've not read the thread fully as pretty much most of it seems dedicated to modding the TMC and I'm not up for that until it's a last resort.
Ta
tonygamble
PostPosted: Tue Feb 20, 2007 6:47 pm    Post subject: Reply with quote
If you touch the vertical bar under the rotating orange disk you should get into a menu page where this 'tune' option will appear.
You can then force the device on to a CFM frequency such as 100.6
Snag is that it will only stay there for a few seconds and then start ploughing up and down all the frequencies where CFM does not transmit.
Clearly TT have not properly programmed the software where you select the country of use - or not for the UK anyway.
So it's actually a waste of time.
Tony
m623d
Trust me, it is a last and only resort. Modding works, non modding doesn't.
If you want a working TMC, mod it asap :P
Garmin Emap, Ipaq 2210 with TomTom Navigator 5, TomTom One, Pioneer AVIC-X1R, TomTom 910 (stolen). TomTom 520, TomTom 6100 (Faulty, replaced under warranty), Currently got a TomTom 6200
manicminer
PostPosted: Tue Feb 20, 2007 11:19 pm    Post subject: Reply with quote
Tony
You guessed right, it worked about the same as coax with the uhf/vhf receiver mounted low on the dash. But I found a dead spot for classic fm and started playing around with the position of the uhf/vhf receiver. I found that the optimum position was central at the top of the windscreen. – Strange thing the boost button does not seen to make any difference to reception
Manic
Nixxrite
PostPosted: Wed Feb 21, 2007 11:30 am    Post subject: Reply with quote
"If you touch the vertical bar under the rotating orange disk you should get into a menu page where this 'tune' option will appear."
Cheers Tony, Only problem I have is that I can't even see a vertical bar or rotating orange disk. Do I have to make at least one connection to classic FM before this becomes available?
M6, I don't have the skills or resources to hand at the moment. I was looking for a quick fix as I'm driving through France in a couple of weeks.
To be honest, I've saddly learned to live with UK road traffic but thought the TMC would be useful... it would appear not so. Sad
tonygamble
PostPosted: Wed Feb 21, 2007 11:39 am    Post subject: Reply with quote
If you can't see the orange disk your TT cannot see your TMC receiver.
Have you pushed the receiver plug well into the docking station? It has a spring loaded element to the plug and, when you have made contact with the TT it will put up a message at the top right of the screen.
Then you'll see the disk.
Look around this thread. I know it is long but it's got several images and I am sure there will be one showing what the disk looks like.
Tony
eurodat
PostPosted: Wed Feb 21, 2007 11:44 am    Post subject: Reply with quote
I have just 'won' one on EBay. I think I should have read this thread before I bid for it. Now i have to decide if I put it straight back on EBay or open it up and mod it. I need to be able to transfer this between vehicles so its not the straight forward mod.
tonygamble
PostPosted: Wed Feb 21, 2007 12:05 pm    Post subject: Reply with quote
"Now i have to decide if I put it straight back on EBay or open it up and mod it."
If you put it back on Ebay you will be selling something that is 'not fit for the purpose for which it is being sold'. And there is evidence here that it was not a mistake. You knew. Not your fault that you found out too late - simply bad luck.
If you open it up you destroy the warranty and if (flying pigs I feel) TomTom withdraw them all and replace them with something that works you will miss out as you've tampered with yours.
The mods are seeming to work. But whether you want all the hassle depends on your spirit of adventure.
I'd be inclined to get the person who sold it to you to take it back and refund your money. Then keep an eye on this thread because you can be sure that the first time anyone gets one to work straight from the packet there will be a big celebration.
Tony
PostPosted: Wed Feb 21, 2007 1:14 pm    Post subject: Reply with quote
Have a read through This Thread where there is an explanation including screen shots of it working. Please make sure your software version is up to date, and that the connector is fully pushed home into its socket on the mount (it is quite stiff) - Mike
stefantapp
PostPosted: Thu Feb 22, 2007 10:37 am    Post subject: Reply with quote
I've just sent mine back to Amazon (Avides Media AG). On a journey from Portsmouth to Mitcheldean (Forest Of Dean) twice, it picked up a signal briefly around Swindon for 15 minutes and that was it.
Avides were more than happy to take it back, let's hope the postal service doesn't lose it, otherwise I'll have to claim on the postal insurance!
IMHO Tomtom should withdraw them, they are not fit for purpose, especially if the only way to get any decent reception is to open it up and mod it!
Stef
m623d
PostPosted: Thu Feb 22, 2007 9:17 pm    Post subject: Reply with quote
Used my modded (just a long peice of wire) receiver on a long run today
M180/M18/M1/A38/Stafford/West Birmingham/M5-Bristol and back
Got a signal 90% of the time and even routed me around a queue!
I have a glass mount amp aerial, but havent gotten around to fixing it yet.
Page 14 of 20
22.063 (19 Jun 24)
