Pocket GPS World :: View topic - latest camera database
tonygold
PostPosted: Wed Feb 14, 2007 1:32 pm    Post subject: latest camera database Reply with quote
need some help please. just downloaded most recent 14th feb release (24 file version) and understand some extra files have been added, but i seem to have 33 ov2 files now. is this right??
also
i still seem to only get boings at certain mobile sites and specs areas. all other cameras work with appropriate ogg voice files just fine. any ideas?? i seem to have appropriate ogg files for all the camera files??
thanks
tony.
tonygold
PostPosted: Wed Feb 14, 2007 1:35 pm    Post subject: Reply with quote
right, just seen the details of latest download and 33 files is correct - so that sorted.
but....
any ideas about my 2nd point re: boings on specs and mobile sites instead of worded ogg warnings.
thanks.
PostPosted: Wed Feb 14, 2007 1:52 pm    Post subject: Reply with quote
the 'some mobile sites' will be the pmobile ov2 files (unverified - 'p' for pending) as you will need a new ogg file to match the name.
re the specs, you need to make sure you have an ogg file with the same name as the specs ov2 and bmp files
tonygold
PostPosted: Wed Feb 14, 2007 2:26 pm    Post subject: Reply with quote
thats the strange thing. i do seem to have correctly named ogg files for the mobiles and specs but still i omly get boings etc.
not a major issue but just baffling me!!!
rugrat2
PostPosted: Wed Feb 14, 2007 6:05 pm    Post subject: Reply with quote
Dont forget to delete the warnings for those cameras, and then reinstall the warning, and it should then pick up on the ogg file..
Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go..
tonygold
PostPosted: Wed Feb 14, 2007 6:28 pm    Post subject: Reply with quote
in my map folder i only seem to have the ogg file, unless you mean delete warning from the actual tomtom unit menu???
how do i do this please??
PostPosted: Wed Feb 14, 2007 8:01 pm    Post subject: Reply with quote
Go through the Warn When Near routine again, for those Cameras that are giving the wrong warning.
If you are still asked to select a warning it means there is something wrong with the naming of that ogg File
tonygold
PostPosted: Wed Feb 14, 2007 8:52 pm    Post subject: Reply with quote
hi oldboy,
when i go into 'manage poi' menu, i select the specs camera,
next screen asks ' delete poi' - i answer no
then i set the yardage warning
then i set warn only if poi is on route
and thats it. it does not ask for a warning sound to be set??
PostPosted: Thu Feb 15, 2007 8:14 am    Post subject: Reply with quote
Then it has picked up the ogg File. Thumbs Up
Just remember that if you Tick for Only Warn When on Route, you won't get any warning at all while using it without Routing Instructions.
pete1336
PostPosted: Thu Feb 15, 2007 10:27 am    Post subject: New ogg file? Reply with quote
For those of us without the correct ogg file for the new pending cams (me) where can I obtain one from?
For the rest of my speed cams I'm using the Liz voice, I'd prefer to use a new Liz ogg file if possible for the pending cams but if there isn't one of Liz I suppose any other human voice will do.
Thanks in advance.
Pete Question
pete1336
PostPosted: Thu Feb 15, 2007 10:49 am    Post subject: Reply with quote
Sorry I should have clarified, mine are the Liz Whittaker voice promps Wink
JockTamsonsBairn
PostPosted: Thu Feb 15, 2007 12:00 pm    Post subject: Re: New ogg file? Reply with quote
Thanks in advance.
Pete Question
Copy the existing ones. e.g. copy Mobile30.ogg to pMobile30.ogg
Jock
pete1336
PostPosted: Thu Feb 15, 2007 1:55 pm    Post subject: Reply with quote
Thank you BGF, much appreciated :D
Mullet
PostPosted: Fri Feb 16, 2007 2:28 am    Post subject: Reply with quote
deleted
pete1336
PostPosted: Fri Feb 16, 2007 12:25 pm    Post subject: Reply with quote
Mullet wrote:
Pete. I have decided to use the single file from the consolidated set as I don't want to use an extra five POIs on my TTNv5.21
I modified an existing .ogg file based on Ray Flanagans Liz Whitaker files simply stating "warning unverified mobile camera ahead" to cover the whole category.
They are louder than the originals so you would need to install the full set.
Too tired to host and cross check right now so PM me your email if you want them.
Done, thank you :D
22.063 (19 Jun 24)
