chuns Occasional Visitor
Posted: Wed Feb 14, 2007 11:40 am Post subject: Navman pin570 forgets favourites and POIs |
My Navman Pin 570 runs tomtom navigator5. If I use the "exit application" feature, when I turn it on again it has forgotten all my favourites and the settings for the POIs. If I simply turn the machine off, it retains everything.
Anybody met this problem before, and more importantly, has anybody got a solution? |
Posted: Wed Feb 14, 2007 12:49 pm Post subject: |
Connect the device to the PC and use windows Explorer to locate the file Current-map.cfg (it will be located in your map folder on the storage card) - copy this file to the PC, right click it and select Properties, is the read only check box ticked? - if so un-tick the check box then copy the file back to the storage card/ map folder and try again - Mike |
Posted: Wed Feb 14, 2007 1:19 pm Post subject: |
Thanks, I'll try that tonight. |
Posted: Mon Feb 19, 2007 1:04 pm Post subject: Thank you... |
...it worked a treat. |
