Pocket GPS World :: View topic - Navman pin570 forgets favourites and POIs
chuns
PostPosted: Wed Feb 14, 2007 11:40 am    Post subject: Navman pin570 forgets favourites and POIs Reply with quote
My Navman Pin 570 runs tomtom navigator5. If I use the "exit application" feature, when I turn it on again it has forgotten all my favourites and the settings for the POIs. If I simply turn the machine off, it retains everything.
Anybody met this problem before, and more importantly, has anybody got a solution?
PostPosted: Wed Feb 14, 2007 12:49 pm    Post subject: Reply with quote
Connect the device to the PC and use windows Explorer to locate the file Current-map.cfg (it will be located in your map folder on the storage card) - copy this file to the PC, right click it and select Properties, is the read only check box ticked? - if so un-tick the check box then copy the file back to the storage card/ map folder and try again - Mike
chuns
PostPosted: Wed Feb 14, 2007 1:19 pm    Post subject: Reply with quote
Thanks, I'll try that tonight.
chuns
PostPosted: Mon Feb 19, 2007 1:04 pm    Post subject: Thank you... Reply with quote
...it worked a treat.
22.101 (03 Oct 24)
