Pocket GPS World :: View topic - sony nvx-p1
sony nvx-p1
user10664
PostPosted: Mon Feb 12, 2007 8:06 pm    Post subject: sony nvx-p1 Reply with quote
can any one tell me what cams i can down load on the sony nvx-p1 as i understand its a navman 650 with sony name on it. and can you use the ogg file for the warnings like you use on the tomtom
any help would be great .
kind regards johnnyh
Tim Buxton
PostPosted: Mon Feb 12, 2007 8:18 pm    Post subject: Reply with quote
Unless the Sony came with its own version of the Desktop application, including POIEditor, it's unlikely that you can upload custom POIs to this particular Sony PND.
Tim
user10664
PostPosted: Mon Feb 12, 2007 8:31 pm    Post subject: Reply with quote
thanks for a quick reply i got it cheap very cheap do you have any views on the sony
thanks john
Tim Buxton
PostPosted: Mon Feb 12, 2007 8:50 pm    Post subject: Reply with quote
Not really. I've only ever seen them in shops. They are, as you say, a rebadged Navman iCN650 and are discontinued with no updates, as far as I'm aware.
Tim
user10664
PostPosted: Mon Feb 12, 2007 8:57 pm    Post subject: sony nvx p1 Reply with quote
ok tim thanks for your help mate
ps if you hear anything about them please email me
I have removed your e-mail address as its not a good idea to post it in the forum due to spam, Your e-mail button will suffice for others to respond to and that is quite safe - Mike Alder
user10664
PostPosted: Thu Feb 15, 2007 4:32 pm    Post subject: post codes Reply with quote
can any 1 tel me is there a way of puting the full post codes on a sony nvx p1 so they will work as the sony does not have full post code serch
any help would be nice
Tim Buxton
PostPosted: Thu Feb 15, 2007 4:40 pm    Post subject: Reply with quote
Again, you'd need either an update from Sony or a way of importing Custom POIs to do this on that unit.
Tim
user10664
PostPosted: Thu Feb 15, 2007 4:59 pm    Post subject: Reply with quote
yes i have the means to do it and have tried puting the post codes on i can do that but it will only let you save up to 99 at a time in poi
hope this makes sence
Tim Buxton
PostPosted: Thu Feb 15, 2007 5:06 pm    Post subject: Reply with quote
Are you sure it will only let you transfer 99? It may only show 99 but might do more. Can you tell me what you're using to transfer the files? I assume they are .asc or .csv files?
Tim
user10664
PostPosted: Thu Feb 15, 2007 6:22 pm    Post subject: Reply with quote
i am using nvx p1 desk top this is the software that comes with it the sony seems to be a very good unit just long winded to do things on not like a tomtom as i am getting a bit sick of it now so if i was to buy a new sat nav is tomtom 910 better than a nuvi 660
thanks john
the software is just like the navman desk top if that helps
Tim Buxton
PostPosted: Thu Feb 15, 2007 6:30 pm    Post subject: Reply with quote
Understand on the Desktop software being long winded. Same here. Did the software come with the unit or did you get it from an IT person?
GO910 is really easy to use. Drag 'n' Drop Custom POIs into the relevant map directory, enable the POIs and off you go. Custom sound warnings are relatively easy, too.
Not sure about the Garmin 660 but I do like Garmins and have a GPS V and the PPC software, too. I reviewed a StreetPilot 2820 not long ago and found it easy to use, though.
Tim
user10664
PostPosted: Thu Feb 15, 2007 8:11 pm    Post subject: Reply with quote
software came with unit
i have now got speed cams on and working
would like road speed to display is there an overlay for speed anyware
Tim Buxton
PostPosted: Thu Feb 15, 2007 8:33 pm    Post subject: Reply with quote
Oh, others said that no software came with theirs. Which Camera DB did you load? The 24 file speed-zoned one should allow the use of their corresponding bitmap files.
Tim
user10664
PostPosted: Thu Feb 15, 2007 9:22 pm    Post subject: Reply with quote
hi speed cams loaded were single file ones as the speed zone ones would have to be loaded one at a time as you can only have one bmp fileper camm so you would have to load the 60 mph cam asc file with the bmp 60 mph so it would match up
i think you do any way not sure but you can only load 1 bmp file with each asc file hope you no what i mean
Tim Buxton
PostPosted: Thu Feb 15, 2007 9:33 pm    Post subject: Reply with quote
I think so. You can have one .bmp per POI file, so if you use the single file you can only have one .bmp. If you use the 24 files, you can have the speed bmp files, too. Yes, it takes longer to load them but it's worth it.
Tim
22.064 (26 Jun 24)
