Pocket GPS World :: View topic - miotransfer hack----instructions?
Dilcymro
PostPosted: Fri Feb 09, 2007 6:02 pm    Post subject: miotransfer hack----instructions? Reply with quote
Hi all, I have made a new folder called miotransfer and extracted the transferhack files into it....then got the mutt file from the mio updater file in my program files and added that. Now I get a miotransfer page on my pc with mp3`s and photos etc , so where do I go from here please. On connecting the mio by usb nothing happens. I havent got it on the miomap page.
Couls someone please clarify please.
Thanks all....Dilwyn
PostPosted: Fri Feb 09, 2007 6:13 pm    Post subject: Reply with quote
i don't want to sound patronising, but have you read the guide here: http://www.pocketgpsworld.com/uksafetycameras-mio.php
Dilcymro
PostPosted: Fri Feb 09, 2007 6:33 pm    Post subject: Reply with quote
Thank you MaFt for the inspiration Laughing
I havent just come down with the last snow shower and yes I have read all that , unzipped the file to a new folder and then added the mutt file....doesnt really tell you any more than that does it? Have also put it into the search bar and drew a blank, hence my request for further info. I appreciate that there are many gifted and knowledgeable people on here , but I`m afraid at my age things of this nature takes a bit longer but pointed in the right direction I can sometimes work things out and I would obviously have had to read all that to get the file in the first place. Without being patronising of course.
I suppose I can always stick to Bluetooth Laughing
Regards....Dil
portman
PostPosted: Fri Feb 09, 2007 6:57 pm    Post subject: Reply with quote
Do you get the usb/mio image on the screen of the mio?
Samsung Mega
Tomtom 500
Dilcymro
PostPosted: Fri Feb 09, 2007 7:22 pm    Post subject: Reply with quote
Hi, no I dont, I connect the mio C510E to the pc using the usb cable and turn it on , all I get is the main menu, as in the photo / settings /mp3 etc page.
Also on connecting get a popup....found new hardware / not recognised.
So I assume that this could be the problem.
Thanks for the reply by the way.
Regards...Dil
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Sallyann
PostPosted: Fri Feb 09, 2007 9:02 pm    Post subject: Reply with quote
Dil,
Are you still running the same shortcut / link?
You should be starting the program "Mio Transfer Hack.exe", NOT "Mio Transfer.exe"
Sal
PostPosted: Fri Feb 09, 2007 10:08 pm    Post subject: Reply with quote
i thought you might have done but seeing as the 'help' file is fairly new i was just checking that you knew of it's existence!
portman
PostPosted: Sat Feb 10, 2007 12:06 am    Post subject: Reply with quote
You may find something relevant here.
http://www.microsoft.com/windowsmobile/help/activesync/default.mspx
Samsung Mega
Tomtom 500
Swordsmaker
PostPosted: Sat Feb 10, 2007 5:13 am    Post subject: Reply with quote
Regards...Dil
It sounds that you are failing already in the USB connection. Did your original Mio Transfer program work properly? If you get a "hardware not recognised" it sounds that your USB driver is missing. Perhaps you should try to reinstall the original program, with drivers and all. To my expericence the Transfer hack works as good (or bad) as the original program, so make sure the original works and then "upgrade" to the hack.
portman
PostPosted: Sat Feb 10, 2007 10:23 am    Post subject: Reply with quote
I wondered the same. You can download just the driver from th mio site here:
http://tinyurl.com/ypxp7e
Samsung Mega
Tomtom 500
Dilcymro
PostPosted: Sat Feb 10, 2007 12:25 pm    Post subject: Reply with quote
Thanks all, been on nights so a bit bogeyed at the moment, I remembered I had removed some of the mio stuff off my pc , so have re-loaded everything including the maps and done another update on the 3.2 version. Now I have to put Phillipa back on again and will now try the safetycams again. I am now getting the pc /usb image on the mio when i attach the usb cable...so will try and work my way throught .
Thanks again...Dil
Dilcymro
PostPosted: Sat Feb 10, 2007 1:27 pm    Post subject: Reply with quote
Hi again, ok I think everything is now sorted, thanks all .
One thing though , on the screen I now get a little circle with "follow" on / in
it, havent seen it before, anyone else had it and what is it for and how do I get rid please.
Thanks again....Dil
