Dilcymro Frequent Visitor
![](http://i60.photobucket.com/albums/h7/dilphoto/welsh-flag.gif)
Posted: Fri Feb 09, 2007 6:02 pm Post subject: miotransfer hack----instructions? |
Hi all, I have made a new folder called miotransfer and extracted the transferhack files into it....then got the mutt file from the mio updater file in my program files and added that. Now I get a miotransfer page on my pc with mp3`s and photos etc , so where do I go from here please. On connecting the mio by usb nothing happens. I havent got it on the miomap page.
Couls someone please clarify please.
Thanks all....Dilwyn |
MaFt Pocket GPS Staff
![](http://maft.co.uk/avatars/pgpsw.jpg)
Joined: Aug 31, 2005 Posts: 15157 Location: Bradford, West Yorkshire
Posted: Fri Feb 09, 2007 6:33 pm Post subject: |
Thank you MaFt for the inspiration
I havent just come down with the last snow shower and yes I have read all that , unzipped the file to a new folder and then added the mutt file....doesnt really tell you any more than that does it? Have also put it into the search bar and drew a blank, hence my request for further info. I appreciate that there are many gifted and knowledgeable people on here , but I`m afraid at my age things of this nature takes a bit longer but pointed in the right direction I can sometimes work things out and I would obviously have had to read all that to get the file in the first place. Without being patronising of course.
I suppose I can always stick to Bluetooth
Regards....Dil |
portman Frequent Visitor
Posted: Fri Feb 09, 2007 6:57 pm Post subject: |
Do you get the usb/mio image on the screen of the mio? _________________ Samsung Mega
Tomtom 500
Posted: Fri Feb 09, 2007 7:22 pm Post subject: |
portman said Quote: | Do you get the usb/mio image on the screen of the mio?
Hi, no I dont, I connect the mio C510E to the pc using the usb cable and turn it on , all I get is the main menu, as in the photo / settings /mp3 etc page.
Also on connecting get a popup....found new hardware / not recognised.
So I assume that this could be the problem.
Thanks for the reply by the way.
Regards...Dil _________________ ***************************************
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Sallyann Lifetime Member
Posted: Fri Feb 09, 2007 9:02 pm Post subject: |
Dil,
Are you still running the same shortcut / link?
You should be starting the program "Mio Transfer Hack.exe", NOT "Mio Transfer.exe"
Sal |
Posted: Fri Feb 09, 2007 10:08 pm Post subject: |
Dilcymro wrote: | Thank you MaFt for the inspiration
I havent just come down with the last snow shower and yes I have read all that , |
i thought you might have done but seeing as the 'help' file is fairly new i was just checking that you knew of it's existence!
MaFt |
Swordsmaker Occasional Visitor
Posted: Sat Feb 10, 2007 5:13 am Post subject: |
Dilcymro wrote: |
Regards...Dil |
It sounds that you are failing already in the USB connection. Did your original Mio Transfer program work properly? If you get a "hardware not recognised" it sounds that your USB driver is missing. Perhaps you should try to reinstall the original program, with drivers and all. To my expericence the Transfer hack works as good (or bad) as the original program, so make sure the original works and then "upgrade" to the hack. |
Posted: Sat Feb 10, 2007 10:23 am Post subject: |
I wondered the same. You can download just the driver from th mio site here:
http://tinyurl.com/ypxp7e _________________ Samsung Mega
Tomtom 500
Posted: Sat Feb 10, 2007 12:25 pm Post subject: |
Thanks all, been on nights so a bit bogeyed at the moment, I remembered I had removed some of the mio stuff off my pc , so have re-loaded everything including the maps and done another update on the 3.2 version. Now I have to put Phillipa back on again and will now try the safetycams again. I am now getting the pc /usb image on the mio when i attach the usb cable...so will try and work my way throught .
Thanks again...Dil |
Posted: Sat Feb 10, 2007 1:27 pm Post subject: |
Hi again, ok I think everything is now sorted, thanks all .
One thing though , on the screen I now get a little circle with "follow" on / in
it, havent seen it before, anyone else had it and what is it for and how do I get rid please.
Thanks again....Dil |
