Arimus Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Joined: 25/11/2002 13:13:12 Posts: 117 Location: Wales, United Kingdom
Posted: Tue Feb 06, 2007 11:34 am Post subject: |
And on my 910 I won't lose data as its got a hdd in it.... those tend not to lose power when turned off (though our server at work seems to have the magically ability to lose data whether it is on or off.... mutter.) |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Tue Feb 06, 2007 2:20 pm Post subject: |
Eldar wrote: | Skippy wrote: |
Even when it is switched OFF ??? |
The internal clock is still running though, so a GO is never completely off unless you use the reset button. |
Are you suggesting thatthere is a way to detect the real time clock in a GPS unit while it's switched off then? _________________ Gone fishing! |
Posted: Tue Feb 06, 2007 2:38 pm Post subject: |
Theoretically with sensitive enough equipment yes, in reality? No.
I think he was on about the fact that even 'off' a TT isn't really off. |
Bigbazza Occasional Visitor
Posted: Tue Feb 06, 2007 2:52 pm Post subject: |
Dhour! Really simple technology is used to detect a device/laptop/etc... the thieves use their bums!, which they sit on in a nearby car, and then use their eyes to watch people coming and going. Then when they see you arrive, take your laptop and put it in the boot and then remove your sat nav and put it in the glovebox, they just wait. Off you go to that meeting...
...the bad boys then go to your car - 1 - break the window, - 2 - open the glovebox (nice Sat Nav) and then - 3- (amazingly) drop down your "Fold down rear seat" to gain access to your boot (without even opening the boot!) to take your laptop and all the data you were planning to backup but just were too busy...
So lookout for people hanging around... sitting in cars... walking by and no-where to go... they might have a keen interest in breaking your window!
The other big giveaway... screen mounts, cables etc - take them off view. |
trafcam Regular Visitor
![](modules/Forums/images/avatars/94626691342d679ef7394f.jpg)
Andy_P Pocket GPS Moderator
Posted: Tue Feb 06, 2007 3:29 pm Post subject: |
We are getting away from the original point...
Even IF this was technically feasible, the prospect of the local thugs having the equipment is laughable.
If they DID get hold of a detector, they would be down the pub flogging it within the hour anyway! |
Posted: Tue Feb 06, 2007 3:45 pm Post subject: |
You're right of course - I suspect this is nothing more than a scare tactic. As others have said, the sophisticated detection methods will be (a) watching vehicles as they arrive, and (b) looking for windscreen mounts.
I must admit when I used mine to find a car park in Manchester last year, I had it way down in the centre console and in night mode so it wouldn't light up the inside of the car, and I switched it off before I got to the entrance "just in case". But it was more about someone seeing it than being invisible to detectors. I would doubt that even the Bluetooth will respond when the device is in standby mode - lots of embedded devices power down parts of the circuitry in standby mode. |
user10664 Occasional Visitor
Posted: Tue Feb 06, 2007 4:42 pm Post subject: gps in glove box |
it is possable to detect a sat nav in the glove box or anyware else in the vehicle but it is not through a radio signal.
it is simply the battery back up in the unit that gives it away as you can detect the voltage from the unit hope this clears this one up dont want to go into two much detail hope you understand
johnny h |
Posted: Tue Feb 06, 2007 4:51 pm Post subject: |
Given the low level of noise that these units generate (otherwise they'd fail to get approval) you need an extremely sensitive detector to pick these signals up from other background man-made noise. |
Darren Frequent Visitor
Posted: Tue Feb 06, 2007 5:12 pm Post subject: |
mike007 wrote: | they must mean that the BLUETOOTH can be searched for,just like on your mobile phone you can "search for devices"
the new tomtom's have bluetooth connection on them. I keep my bluetooth switched off as i dont use it. |
When I read the original news item on the BBC Website I contacted them to correct the innacurate statements.
I've just has a reply from the author of the story. He 'thinks' that the reference was with regard to detecting the Bluetooth Radio but this would require that both the GPS and BT were left On, unlikley methinks!
Even were this the case, the satnav is not being tracked and the story is misleading. It is a simple process to scan for Bluetooth devices that are in 'discoverable' modes, but that does not help you locate a device unless you're in the middle of a large car park and there's only one car there
The author has passed my comments on to DS Agar for his response. I'll let you know what if anything comes of it! _________________ Darren Griffin
skr00ge Occasional Visitor
Posted: Tue Feb 06, 2007 6:24 pm Post subject: Re: gps in glove box |
johnnyh wrote: |
johnny h |
You won't want to go into much detail because it sounds like guff. The kind of equipment required to detect a lion battery inside a metal car shell with all the live 12V, HT coil and live car electronics would have to be some serious magic. If you had this kind of detection you'd be working in a physics research lab or have a few thousand quid spare, not robbing cars for 50 quid fences of sat nav gear.
And they can tell the difference between a SatNav and my £10 mobile?
Far better detecting the resonant frequency of the invertor circuit for the TFT eh?
Sorry my credulity just stretched too far.
Cheers |
Posted: Tue Feb 06, 2007 6:49 pm Post subject: nav in glove box |
you just cannot get through to some people
be good.
if you new what i did for a living you would listen
if you email me i will tell you |
Posted: Tue Feb 06, 2007 7:22 pm Post subject: |
If it involves the people in the Cheltenham doughnut then there remember the kit they play with is beyond the kit joe public can play with ;) |
Eldar Pocket GPS Moderator
Posted: Tue Feb 06, 2007 7:26 pm Post subject: |
Arimus wrote: | If it involves the people in the Cheltenham doughnut then there remember the kit they play with is beyond the kit joe public can play with ;) |
yes, but if one of them spooks leaves his gear in the car as the MI5 boys do from time to time with their laptops, then it can get nicked and used to detect TomToms! |
Posted: Tue Feb 06, 2007 7:37 pm Post subject: |
True.... assuming the crook can get the bloody thing to work - most of the gov't stuff needs a good kicking first to get it going. |
