Mikeact Frequent Visitor
Joined: Nov 29, 2004 Posts: 303 Location: West Sussex
Posted: Thu Feb 01, 2007 9:33 am Post subject: TT Home...latest version |
Before I call TT, anybody noticed the following ??
Getting home last night, there was a TT message on their/my TT Home page to download the latest version which I did.
Now I am unable to do a backup to TT Home...it has crashed 5 times so far. |
Calomax Lifetime Member
Joined: Sep 30, 2005 Posts: 988 Location: St Martin's, Guernsey
Posted: Thu Feb 01, 2007 12:11 pm Post subject: |
Mike, I downloaded it last night and it experienced a problem & closed down while it was checking my device. It appeared ok when I opened it again but I haven't tried a backup yet. I'll give it a try tonight when I get home. 8O _________________ TT Go Essential |
hope68 Regular Visitor
Posted: Thu Feb 01, 2007 1:55 pm Post subject: |
faced the same problem after TT-Home downloaded and installed the new version. The program kept freezing all the time as soon as i connected my PDA.
Deinstalled TT-Home, cleanded the registry and downloaded latest Version from the TT-Homepage. Installed it and it worked fine.
So, havent done a Back-Up by now with TT-Home as im used to do a back-up with Sprite.
cu Peter |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Thu Feb 01, 2007 4:06 pm Post subject: |
Downloaded the latest version of TTHOME just today. I was having all sorts of probs with TTV6.01 on my PDA. A failed installation of an app seemed to stop it from working.
Used new verion of TTHOME (1.5.xxx) to restore entire TT6 system - no problems.
Tried to use it to back up system and it just won't do it - it seems to remember the file structure of the contents of the SD card prior to me erasing it for restore. It gets part way into the backup up and crashed out trying to backup a folder that is not there anymore - had a poke about in the registry but can't see anything relevant. Tried re-install - cleaning out all obvious registry entries - still same.
I have reported it to TomTom Support. |
Posted: Thu Feb 01, 2007 10:52 pm Post subject: |
I had many problems with the updated version of TT HOME. I installed it last night and it crashed while checking my device.
When I started it today it couldn't find my device at all. I eventually uninstalled it and put version 1.3 back on, luckily I had saved it when I originally downloaded it, and all was well.
I tried the update again so, when the message came up, I clicked "Yes" and downloaded it again. When it started it checked the device then gave a message that I was logged in with a different email address to the one associated with this device, I tried to login using the same email & password as I use for "My TomTom" which didn't work, so I tried to register a different one with the same result. :x
Then I tried to back up when I was told there was no TomTom device connected, even though it explored it ok.
I tried to look at the online store but had a message that the connection with the server had been interrupted.
then I gave up and unstalled it again and reinstalled version 1.3. Immediately all my troubles were over again. I was logged in as my usual login, I could back up, and look at the online store. The only difference that I can see is that the updated version has a "Copy to PC" facility and there are other ways to do that. :D
Needless to say I am staying with version 1.3 until I hear that these problems have been resolved. _________________ TT Go Essential |
Posted: Thu Feb 01, 2007 10:58 pm Post subject: |
Just read through the thread again and noticet that hope68 had downloaded version 5 from TTs website so maybe it's the downloaded update that is the problem. I might give it a try sometime but not now. _________________ TT Go Essential |
Posted: Fri Feb 02, 2007 1:51 pm Post subject: |
Calomax wrote: | Just read through the thread again and noticet that hope68 had downloaded version 5 from TTs website so maybe it's the downloaded update that is the problem. I might give it a try sometime but not now. |
I tried both (that is the automatic download and a fresh download from TT site - same problem - can't get to do backup).
Using an older 1.3 version on laptop is OK though - so will be staying with this for the time being.
Phil |
Posted: Fri Feb 02, 2007 7:20 pm Post subject: |
I tried some things today and it seems that TT-Home doesnt like my 2GB-SanDisk-SD-Card when in the x50v and TT-Home is not responding.
If I use a smaller Card (an old 128 MB SD-Card) it works fine.
When the SanDisk is in the Card-Reader its no problem at all.
cu Peter |
billconant Occasional Visitor
Joined: Jul 19, 2006 Posts: 27 Location: Quincy, Massachusetts USA
Posted: Fri Feb 02, 2007 7:45 pm Post subject: |
I had the same login problem with the new version. I closed it down and reopened it and worked without the login problem. In fact it automatically connected to TOmTom.
Bill |
Posted: Fri Feb 02, 2007 7:49 pm Post subject: |
I just tried it again. Clicked on create new account and used my normal tt login. Then was told an account with that name already existed. But there was an "Update account" button. Clicked that and was immediately logged in. Fingers crossed that it all works ok now. _________________ TT Go Essential |
Posted: Fri Feb 02, 2007 11:11 pm Post subject: |
Fingers crossed, I think I've fixed it but I'm not too sure how. I uninstalled v1.3 and installed v1.5 again a couple of times. I did keep getting the "device connected to my computer is not associated with this account" message, but went to "create new account" and put my normal tt login details again. I was told that user name was already in use. Then I clicked on an "Update account" button and immediately logged in with no problem.
Now all seems well except the Backup which tells me that there is no TomTom device even though I had just downloaded and installed a cllour scheme.
I'm not bothered about the backup system as there are better ways, but hopefully everything else is working well. :D
But it just crashed. Hope that's not an omen. _________________ TT Go Essential |
alanjrobertson Occasional Visitor
Posted: Fri Feb 09, 2007 11:41 pm Post subject: |
1.5 seems to be an improvement for me. I'm running TTN6 on my Palm TX (it works absolutely fine apart from an occasional startup bug so I don't know why they don't just support it!) but had issues getting it to recognise the SD card with the TTN software on it. This update seems much more consistent and works well - perhaps they improve this bit of the software because everyone is having to go down the SD card reader route at present in Vista?
Alan |
Posted: Wed Feb 14, 2007 10:52 pm Post subject: |
I've been emailing TomTom support about the problems with the updated TTHOME (Version 1.5.032) which keeps crashing and can't see the device if I want to backup. But I did get it to work ok with a card reader.
I had this message from them today Quote: | Thank you for contacting TomTom Customer Support.
At the moment we are having some challenges with the new TomTom Home version; please in the meantime continue to use the older version of TomTom Home |
I have asked, if I continue to reject the update when I turn HOME on, how I'll know when a new update is available which will cure the problems. I would expect that it would be published it on the website but maybe not, bearing in mind I was unaware that version 1.5.024 had been withdrawn. _________________ TT Go Essential |
Oldboy Pocket GPS Moderator
Posted: Thu Feb 15, 2007 8:39 am Post subject: |
If anyone wants to revert to 1.3_308, and hasn't got a copy, it's on my Updates Page. _________________ Richard
coconut Regular Visitor
Joined: Jan 31, 2005 Posts: 87 Location: Staffordshire
Posted: Fri Feb 16, 2007 4:41 pm Post subject: |
My newly installed TomTom Home freezes when trying to use the Back Up facility ( for my Ipaq 6916 ) so I e-mailed TomTom and this is what they said :
"May we apologise for the delay in responding to your query. I have heard from 2nd line support team and they have told me that a backup of the SD-card on a PDA using TomTom HOME will not currently work. They suggest making a manual backup of the SD-card by copying all files and folders from the card to your PC.
With Best Regards
The TomTom Customer Support Team"
Hopefully they are working on a fix _________________ iPhone SE, TomTom Go 5000, Garmin Zumo XT. |
