Pocket GPS World :: View topic - Help - Need nokia cable to gps device
magzy
PostPosted: Tue Oct 17, 2006 5:44 pm    Post subject: Help - Need nokia cable to gps device Reply with quote
I have a nokia 3230 smartphone with tomtom mobile5 installed.
Without using bluetooth, how can I get tomtom to work with a gps receiver via a cable?
Is this possible?
Thanks,
M
Pc-Mobile
PostPosted: Thu Oct 19, 2006 2:35 pm    Post subject: Reply with quote
Sorry as far as I know no phone, whatever the make, can connect any GPS with a cable.
so it is bluetooth only.
Pc-Mobile
http://pc-mobile.net/gps.htm
mrLenin
PostPosted: Thu Feb 01, 2007 5:08 pm    Post subject: Reply with quote
What about DCU-5 cable? It has to connect . Am I mistake?
Article Directory
Article Robot
philpugh
PostPosted: Thu Feb 01, 2007 5:28 pm    Post subject: Reply with quote
Physically it would connect - but you would need to put a null-nodem between the phone and the GPS serial connector as both devices expect to talk to a PC. Basically you need to swap the recieve and transmit cables around (Pins 2 and 3) on one of the cables only. You can buy these devices at most places that deal with serial cables.
After that it would be a matter of finding out if the application on the 'phone can attach to the COM port associated with the serial device on the phone. It may be that it is reserved for use by the phone's synch operation and not available for others apps.
To be honest it's not a very elegant solution. BT is the way to go - a cheap BT receiver would cost about the same as the two cables and null modem required.
mrLenin
PostPosted: Thu Feb 01, 2007 5:35 pm    Post subject: Reply with quote
Understand. Thanks for advice.
Article Directory
Article Robot
Pc-Mobile
PostPosted: Sat Feb 03, 2007 4:15 am    Post subject: Reply with quote
There are many phones with a serial cable. So yes you can connect physically.
But will it work? I do not think so.
I do not think there is any software that can use the serial port on the phone to connect a GPS.
That was why: "as far as I know no phone, whatever the make, can connect any GPS with a cable"
New software may change that.
Pc-Mobile
mrLenin
PostPosted: Mon Feb 05, 2007 10:28 am    Post subject: Reply with quote
TomTom has a original Bluetooth GPS Charging Cable. Cable suitable for charging Bluetooth GPS through TomTom Cradle, Arkon GPS Mount or Seidio G2500 Mount. Provide many solution including mobile phones.
Article Directory
Article Robot
23.084 (27 Aug 25)
