Pocket GPS World :: View topic - Garmin GTM 10 £64.99 + £4p&p
portman
PostPosted: Fri Jan 26, 2007 1:27 pm    Post subject: Garmin GTM 10 £64.99 + £4p&p Reply with quote
Whilst routing around on amazon I found the GTM 10 going for a good price. Here are the links for Amazon and the companies normal websites, i think they are the same company.
http://s1.amazon.co.uk/exec/varzea/ts/exchange-glance/Y05Y4041814Y7599519/202-1968916-7990204
http://www.dynamicsounds.co.uk/garmin-m-22.html?osCsid=0d0c569854d8146c08e360f650e4d984
Here it is listed at £68.49 + £4 p&p.
http://s1.amazon.co.uk/exec/varzea/ts/exchange-glance/Y09Y3959653Y8053132/202-1968916-7990204
http://caraudiosecurity.com/shop/home.html
Samsung Mega
Tomtom 500
swing
PostPosted: Fri Jan 26, 2007 6:10 pm    Post subject: Reply with quote
The only warning I would give is that I believe they are possibly selling the Kenwood GTM10, and not the Garmin GTM10. Although it's the same device, the Garmin version comes with more aerial converter connectors, which may be an issue to some. Obtaining these converter cables is not easy.
portman
PostPosted: Fri Jan 26, 2007 10:44 pm    Post subject: Reply with quote
You mean like this one.
http://www.justkenwood.co.uk/stock01/gtm10.asp
Samsung Mega
Tomtom 500
portman
PostPosted: Fri Jan 26, 2007 11:05 pm    Post subject: Reply with quote
Also available from currys at only £135!!
The car aerial adapters can be found easily for £3-4 each so max £8.
I've fitted the GTM 10 to my car and using the Nuvi 310 my max signal strength around Portsmouth was 90, yes 90! compared with a max of 15 with the GTM 12. This is using GTM software version 3.7 not the new 3.9.
http://www.currys.co.uk/martprd/product/seo/In-Car+&+GPS/In-Car+Entertainment/Accessories/Kenwood/GTM10/242045
Samsung Mega
Tomtom 500
swing
PostPosted: Sat Jan 27, 2007 12:25 pm    Post subject: Reply with quote
Where can you get the Garmin Fakra connector for £3-4 from please?
portman
PostPosted: Sat Jan 27, 2007 2:20 pm    Post subject: Reply with quote
Assuming that you get the leads in the picture all you would need is the iso adapters like these.
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=98812&doy=27m1
http://www.maplin.co.uk/Search.aspx?C=SEO&U=Strat16&doy=search&Criteria=A36FL
http://cgi.ebay.co.uk/AUTOLEADS-ISO-TO-DIN-AERIAL-ADAPTOR-FREEPOST_W0QQitemZ220072683072QQihZ012QQcategoryZ14932QQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/AUTOLEADS-DIN-TO-ISO-AERIAL-ADAPTOR-FREEPOST_W0QQitemZ220072783470QQihZ012QQcategoryZ14932QQrdZ1QQcmdZViewItem
Samsung Mega
Tomtom 500
swing
PostPosted: Sat Jan 27, 2007 4:51 pm    Post subject: Reply with quote
Good finds there!
However, that only covers the ISO and the DIN connectors that Garmin would have put in the box. Anyone with a Fakra car aerial (All VAG cars - Audi, VW, Seat, Skoda) still can't connect the stereo.
However, you are right that the adaptors are out there for the majority of cars.
portman
PostPosted: Sat Jan 27, 2007 7:30 pm    Post subject: Reply with quote
Is this a test?
Not sure what a VW one would look like, but whether you bought the Garmin or the Kenwood one you'd still need an adapter, can't be more than £15.
Samsung Mega
Tomtom 500
swing
PostPosted: Sat Jan 27, 2007 8:51 pm    Post subject: Reply with quote
No, it's not a test, I'm simply informing you of the situation (and anyone else reading this thread).
As I've said, the VAG range use a Fakra car aerial connector - if you buy the Garmin GTM10, the connector for that (and 2 other car aerial types are included in the box) - if you buy the Kenwood GTM10, you only get 1 type of car aerial connector. Fakra connectors are nigh on impossible to obtain (as are adaptor cables for Fakra) and hence people need to be aware of the differences between the two models before assuming that these companies are selling the same device as listed on the Garmin website.
portman
PostPosted: Sat Jan 27, 2007 10:53 pm    Post subject: Reply with quote
I presume the end of the VW antenna lead has a fakra connector that goes straight in to the GTM 10. If this is the case just connect up the two din/iso leads supplied to make a double ended fakra lead to plug into the stereo.
Samsung Mega
Tomtom 500
swing
PostPosted: Sun Jan 28, 2007 12:30 pm    Post subject: Reply with quote
Oh, nice idea!
locksmith
PostPosted: Wed Jan 31, 2007 12:22 pm    Post subject: Reply with quote
Just to get this clear in my mind. Will this GTM 10 work with my Nuvi310 and connect into my Vivaro van radio?
http://cgi.ebay.co.uk/KENWOOD-GARMIN-GTM-10-TMC-TUNER-ADD-ON-BOX-NEW_W0QQitemZ330080155785QQihZ014QQcategoryZ75327QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
tkerby
PostPosted: Wed Jan 31, 2007 2:27 pm    Post subject: Reply with quote
Only problem I see with these is the stereo must be turned on if you have a retractable aerial Sad
swing
PostPosted: Wed Jan 31, 2007 3:51 pm    Post subject: Reply with quote
It should work if your Vivaro has the same aerial connector as shown in the picture, although please don't blame me if it doesn't work.
portman
PostPosted: Wed Jan 31, 2007 4:05 pm    Post subject: Reply with quote
If the end of your Vivaro antenna lead has a 'female' fakra connector on it, it will connect straight in to the GTM 10. If it has a din or iso connector you just have to use the connectors suppied with the GTM 10.
The female fakra connector is on the far left, the iso/din are the two on the right.
http://www.incarexpress.co.uk/catimages/accs/pc5111.jpg
Samsung Mega
Tomtom 500
22.055 (29 May 24)
