Pocket GPS World :: View topic - POI won't display in Navigation mode
tonys66
PostPosted: Sat Jan 27, 2007 6:09 pm    Post subject: Reply with quote
Have you exceeded your poi amount ie i think tt510 is 50 or 100 where a 910 is a lot more .
Say wot device you are using and we can help more
PostPosted: Sat Jan 27, 2007 6:28 pm    Post subject: Reply with quote
The limit for Custom POI categories using TomTom version 6 is 100 irrespective of the device type, that said check your map folder for the number of files ending with the file extension .ov2 (assuming version 6 software is in use, if you have the version 5 software don't go over 39 custom categories) - if you are over the limit try removing some, if you are under the limit simply enable the POI in Change Preferences/ Manage POI/ Enable \ Disable POI - Mike
PostPosted: Sat Jan 27, 2007 6:33 pm    Post subject: Reply with quote
Right idea, wrong numbers, Tony 8)
It is the software version that determins the number of user-added POI categories.
v6 software allows 100
v5 and earlier allows 39 (except for one version (v5.2?) where it dropped to 27!)
Number of actual entries in any POI category is virtually unlimited.
PostPosted: Sat Jan 27, 2007 6:37 pm    Post subject: Reply with quote
Beaten to it yet again!
This board is weird... I always 'preview' my posts and check below it to see if anyone else has replied while I was writing my reply.
There certainly wasn't this time, but when I press 'Submit' I find someone else's IS there! Confused
PostPosted: Sat Jan 27, 2007 6:48 pm    Post subject: Reply with quote
Sorry Andy, No explaination for that one, I actually checked with Preview prior to posting (although with a 5min difference I would have expected your preview to include my response) - at least the answers were the same Wink - Mike
mrzipy
PostPosted: Sat Jan 27, 2007 6:52 pm    Post subject: Reply with quote
Had same problem here, select reset factory settings in the menus then suddenly enable POIs you enable display on the screen again.
PostPosted: Sat Jan 27, 2007 7:03 pm    Post subject: Reply with quote
Embarassed I'd even said to MrZipy that it was worth remembering that trick!
22.071 (03 Jul 24)
