Pocket GPS World :: View topic - co-pilot live 4 mobile interaction
benyyy
PostPosted: Sun Feb 15, 2004 11:21 pm    Post subject: co-pilot live 4 mobile interaction Reply with quote
can this be setup so the the base pc can track several vehicles running co-pilot live aswell as message between pc and mobile unit
thanks in advance........
PostPosted: Sun Feb 15, 2004 11:32 pm    Post subject: Reply with quote
yes, as long as your mobile phone supports both BlueTooth and GPRS, and your PocketPC can handle BT connections both to the GPS receiver and to the mobile at the same time.
Of course this is all much easier with a XDA II or the like.
benyyy
PostPosted: Mon Feb 16, 2004 9:52 pm    Post subject: further info required Reply with quote
so what if i use a ipaq 3660 or 3850 or 3950, what exactley is required to setup these, my mobile already has both blutooth and gprs although i dont know how to configure things there.
thanks for the help on this.
PostPosted: Tue Feb 17, 2004 12:18 am    Post subject: Reply with quote
You need a BT enabled PocketPC. A 3970 would do, for example.
- you connect the PocketPC to a serial or BT GPS receiver
- you connect the PocketPC to the Internet via your GPRS mobile phone.
- you have a desktop computer running and connected to the internet, so it can trace the position of the PocketPC, and can initiate the two way conversation.
That's all you need (apart from the CoPilot software)
pgamble
PostPosted: Thu Feb 19, 2004 2:04 pm    Post subject: Multiple clients Reply with quote
Hi .... I think the question was, can a single desktop monitor and message multiple CPL GPRS connected users.
Answer today I believe is no. The software is only designed to handle one and this is because the desktop and client s/w are linked via key. I suspect this will change in the future.
PostPosted: Thu Feb 19, 2004 2:15 pm    Post subject: Reply with quote
That is correct, you can only monitor a single user and this is hard coded via installation key. Even if you purchased multiple copies of the package you would only be able to monitor multiple users if you installed the workataion client on multiple PC's as well Sad
PostPosted: Thu Feb 19, 2004 2:22 pm    Post subject: Reply with quote
There is some confusion in the versioning. As far as I know version 4.0.107 does only support a single client but version 4.5.2.9 allows you to monitor multiple clients from one desktop
