Pocket GPS World :: View topic - Nuvi 360 - Map Outlines setting ??
BrummyGit
PostPosted: Tue Jan 23, 2007 10:04 pm    Post subject: Nuvi 360 - Map Outlines setting ?? Reply with quote
I've had Garmin satnav devices for years but only recently bought a Nuvi 360. I can't work out what the "Map Outlines" setting does. The manual says:
Map Outlines - turns on or off the supplemental map outlines
I'm non the wiser, can you educate me?
Paddywack
PostPosted: Tue Jan 23, 2007 10:53 pm    Post subject: Reply with quote
If you zoom way out (till you can see a whole country) if you have map outlines on you will be able to see the lines between adjacent map tiles.
BrummyGit
PostPosted: Tue Jan 23, 2007 10:59 pm    Post subject: Reply with quote
Thanks but I've just zoomed out and they don't show on mine.
BrummyGit
PostPosted: Tue Jan 23, 2007 11:01 pm    Post subject: Reply with quote
Sorry what I should have said was I always see country boundaries when I zoom right out - independant of the setting. But I never see the map tiles like I used to on older Garmin units.
swing
PostPosted: Wed Jan 24, 2007 7:56 am    Post subject: Reply with quote
If you have a standard Nuvi 360 with no additional maps installed (beyond the full European mapping installed as standard) then there will be no additional maps to show the map outlines.
It's designed for adding 3rd party maps, topo maps, or for users of the lower models (such as the 310) to allow them to see which areas are / aren't subject to a more accurate map than the basemap.
Paddywack
PostPosted: Wed Jan 24, 2007 7:30 pm    Post subject: Reply with quote
Apologies I have a Nuvi 300 and had assumed that the map outline setting would be the same across the range Embarassed
BrummyGit
PostPosted: Wed Jan 24, 2007 9:41 pm    Post subject: Reply with quote
No apology needed. You tried to help - and indeed were correct. My map is one seemless map of Western Europe which is why I see no boundaries.
Thanks for helping.
Steve
22.063 (19 Jun 24)
