Pocket GPS World :: View topic - tomtom 300 big problem
mort66
PostPosted: Mon Jan 22, 2007 7:37 pm    Post subject: tomtom 300 big problem Reply with quote
hi all, my tomtom 300 is playing up. when i power up it needs speed cam poi resetting and it wont store my home settings anyone else had this ?
PostPosted: Mon Jan 22, 2007 7:52 pm    Post subject: Reply with quote
Has the write/ lock switch on the memory card been accidentally pushed to the wrong setting i.e. LOCK, if so switch it to the other position to un-lock it and try again - Mike
mort66
PostPosted: Mon Jan 22, 2007 8:38 pm    Post subject: thanks but ? Reply with quote
how do i sort it. is it the reset button near the w/screen mount
mort66
PostPosted: Mon Jan 22, 2007 8:50 pm    Post subject: found it Reply with quote
found it but still no good
Oldboy
PostPosted: Tue Jan 23, 2007 7:59 am    Post subject: Re: thanks but ? Reply with quote
Not the Reset Button.Confused
PostPosted: Tue Jan 23, 2007 2:19 pm    Post subject: Reply with quote
You could also try checking to see if the .cfg file in your map folder (either called Map_Settings.cfg or {mapname}.cfg) has been accidentally switched to "read only"
Do this by connecting the Go to the PC and using Windows Explorer (not Internet Explorer) to find the file in your Go's map folder. Right click on the file and select "properties". Check there is NO tick in the "read only" box at the bottom. If there was, remove it and click "Apply".
To be honest, I don't know if the Linux-based Go will take any notice of this setting, but it's probably worth a try.
22.064 (26 Jun 24)
