djben9 Occasional Visitor
Posted: Sun Jan 21, 2007 5:12 pm Post subject: speedcameras and other POI's uploading question |
i downloaded some POI's from Mafts site a while back, can these be added when i upload the speedcameras with the POI loader???, sometimes it handy to have a few supermarkets on there when in unknown towns!
cheers |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Mon Jan 22, 2007 2:01 am Post subject: Multiple .GPI files |
Assuming the Nuvi works like the Streetpilot C510, you can have multiple ".GPI" files in the \Garmin\Poi directory.
So, you could upload your Supermarkets etc using POILoader and then rename POI.GPI to MyPoints.GPI.
If you then re-run POILoader with the speedcamera database, you'll get another POI.GPI, which you can leave as-is or rename to Speedcamera.GPI if you feel that way inclined.
The order it finds these files, affects the order they show up in the list. So if you want your 'Supermarkets' first, load them and boot up the Nuvi. Then shutdown, reconnect to PC and transfer on Speedcameras etc.
At any rate, that works for the Speedpilot... |
swing Pocket GPS Verifier
Posted: Mon Jan 22, 2007 11:41 am Post subject: |
Or you can simply put all the files in the same directory, and let POI Loader just upload them all to the unit...
The latest POI Loader supports categories on many Garmin units, and MaFt has produced a version of his POIs that already the POIs split into categories.
By putting everything into categories, it's a lot easier to see what going on anyway, without the need to order the files explicitly. |
Posted: Mon Jan 22, 2007 5:41 pm Post subject: |
cheers guys, i'll try it out when i get some time |
Posted: Mon Jan 22, 2007 6:53 pm Post subject: |
swing wrote: |
I keep seeing references to 'categories', (in Mapsource, NRoute etc). It doesn't seem to be a concept that the Speedpilot C510 implements, unless someone can enlighten me. I've tried defining some POI's as .GPX files and adding the relevent "gpxx:Category" statements - I don't get any errors, but equally they don't seem to do anything either.
Maybe it's just something that the POI loader doesn't propagate through to the .GPI file. There are others features that the units are capable of that aren't implemented (yet?) ... for example. the Cyclops/Garmin speed cameras don't show up as Custom POIs (you can't select them as somewhere to navigate to!) - yet they obviously are, in every other sense. |
Posted: Mon Jan 22, 2007 7:16 pm Post subject: |
The latest POI Loader (Beta version) supports categories by you simply placing the POI files on your PC within sub directories, and it then creates those subdirectories as categories on the SatNav unit. |
