MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Mon Jan 08, 2007 4:46 pm Post subject: |
woohoo!
finally, speed zoned ;)
donation sent - much appreciate all your work with this!
MaFt |
Posted: Mon Jan 08, 2007 5:13 pm Post subject: |
ps - can't you do it so it actually uses the speed-zoned download so we can have the different icons for mobile / gatso / specs etc?
MaFt |
Ash10 Pocket GPS Verifier
Posted: Mon Jan 08, 2007 7:19 pm Post subject: |
MaFt wrote: | ps - can't you do it so it actually uses the speed-zoned download so we can have the different icons for mobile / gatso / specs etc?
Problem is that would use up a sizeable chunk of the available POI categories on an i3 (and possibly others, too) - it also makes scrolling through the menu unwieldy. |
ILoveSatNav Occasional Visitor
Posted: Wed Jan 10, 2007 3:09 pm Post subject: |
Hi Ash
Is there any way your fantastic Camera Manager can be used with the POI loader that has .wav files enabled. I have tried using CBROMs version with the wav files and it works really well by telling you the type of camera and what speed it is - but VERY annoyingly keeps on telling you!!
using the info below (posted elsewhere), could it be possible to have your versions speed cams named as below so we could use the wav files available :
(this is an extract from this thread: POI Loader software version 2.4.0.0 Beta)
1/ Download and install Audacity to your PC, don't worry its free.
This software package can be used to create your own files using a microphone or use it to convert ogg files to the wav format.
There are a number of other sat nav systems using the ogg file format, so there is a variety of ready made audio file sets for camera warning. One excellent source is Ray's site which can be found HERE the voice files you want are located at the bottom of the linked page, in 22050Hz format. There are three to choose from.
2/ Use Audacity (or any other good audio package) to open each individual track then use the file/ Export as WAV option.
3/ Re-name the files to match the file set you use:
For those using the Single file download:
pocketgps_uk_sc.wav
For those using the consolidated by type file download:
pocketgps_uk_gatso.wav
pocketgps_uk_mobile.wav
pocketgps_uk_redlight.wav
pocketgps_uk_specs.wav
pocketgps_uk_temp.wav
For those using the Speed Zoned file type download:
pocketgps_uk_gatso_20.wav
pocketgps_uk_gatso_30.wav
pocketgps_uk_gatso_40.wav
pocketgps_uk_gatso_50.wav
pocketgps_uk_gatso_60.wav
pocketgps_uk_gatso_70.wav
pocketgps_uk_gatso_tba.wav
pocketgps_uk_gatso_var.wav
pocketgps_uk_mobile_20.wav
pocketgps_uk_mobile_30.wav
pocketgps_uk_mobile_40.wav
pocketgps_uk_mobile_50.wav
pocketgps_uk_mobile_60.wav
pocketgps_uk_mobile_70.wav
pocketgps_uk_moblie_tba.wav
pocketgps_uk_specs_20.wav
pocketgps_uk_specs_30.wav
pocketgps_uk_specs_40.wav
pocketgps_uk_specs_50.wav
pocketgps_uk_specs_60.wav
pocketgps_uk_specs_70.wav
Use the above as a tick list to compile your file list, most of the above are available already, only the mobile 20 and gatso 20 require creation for a full set, I use the basic mobile or Gatso warning for the files that are missing, simply duplicate the file and name accordingly..
4/ Put all the wav files in the same folder as your bmp/ csv files, then use the new Beta POILoader to install the files to the device.
Mike
I have tried your versions with the wav files but as they aren't the same as the ready made wav files, the unit doesn't see them. Equally the ready made wav files are camera and speed specific - which really helps!
Would really appreciate your views! Thanks! |
djben9 Occasional Visitor
Posted: Wed Jan 10, 2007 3:35 pm Post subject: |
have to have a look at this WAV thing, can i be done with the Nuvi 310 (sorry fairly new to the forum and brwose more than post)
Ash,
after my recent problems with the earlier camera manager, the last version and this work fine!! :D :D , keep up the good work :D
(i do quit it each time and then run it again from the downloaded file once a week, as it works i'll try leaving it on and restarting next time) |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Wed Jan 10, 2007 4:29 pm Post subject: |
djben9 - yes, you can use the WAV files with the Nuvi 310 - you'll need to use the beta version of POI Loader, and it only works with the Speed Zoned Garmin PGPSW database version (until Ash is able to support them too).
Some people have reported some problems with this version of POI Loader though (it is a beta version). |
DPL Regular Visitor
Posted: Sat Jan 13, 2007 9:05 pm Post subject: |
Hmmm. Seem to have made a mess of things...Been running Camera Manager happily and successfully for some months. Now I've downloaded the latest 1.5 beta version having deleted the previoius camera database file as advised first. Everything runs ok but the latest 11jan07 database is not pulled down and the toolbar icon remains as advising that updates are available. I've run POI Loader now three times but no improvement.
Ideas anyone? _________________ Garmin C320 & Garmin Quest |
Posted: Sun Jan 14, 2007 3:23 am Post subject: |
DPL wrote: | Hmmm. Seem to have made a mess of things...Been running Camera Manager happily and successfully for some months. Now I've downloaded the latest 1.5 beta version having deleted the previoius camera database file as advised first. Everything runs ok but the latest 11jan07 database is not pulled down and the toolbar icon remains as advising that updates are available. I've run POI Loader now three times but no improvement.
Ideas anyone? |
make sure you're logged into the forum in internet explorer... i use firefox and always forget to log in every now and then via IE cos for some reason it 'forgets' to stay logged in!
MaFt |
DPL Regular Visitor
Posted: Sun Jan 14, 2007 9:46 am Post subject: |
There's only one thing to say ... _________________ Garmin C320 & Garmin Quest |
tomthompson Frequent Visitor
Joined: 26/08/2003 15:43:37 Posts: 386 Location: Southampton, UK
Posted: Mon Jan 15, 2007 9:50 pm Post subject: |
Worked straight out of the box for me on my 2720 . Just followed instructions to remove previous zip file.
Havent yet had the nerve to try the beta POI loader as the 2720 is not quite so easy to recover should it go belly up
_________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ? |
paul3 Occasional Visitor
Posted: Wed Jan 17, 2007 5:09 pm Post subject: |
Hello Ash10/all,
Can you help me please?, I have tried to download your software using IE6/Firefox with or without antivirus turned on, and always have the same problem which is CameraManager MFC Application has encounterd a problem and needs to close.
On closeing this window the software shuts down?
Many thanks
Paul. |
emjaiuk Frequent Visitor
Joined: Dec 06, 2003 Posts: 335 Location: North Surrey (TW17) UK
Posted: Wed Jan 17, 2007 5:59 pm Post subject: |
paul3 wrote: | Hello Ash10/all,
Many thanks
Paul. |
I had this, on XP Home 1, and had to use the system restore facility, and redownload Camera Manager to correct it. The first time I tried it I had Firefox and IE open at the same time, the second time I only had IE open _________________ Go740L App 9.510 Europe 985.8155
RDS_TMC mount
Home 2.8.3.2499 Win10 Home |
Posted: Thu Jan 18, 2007 5:36 pm Post subject: camera manager |
Emjaiuk,
Thanks for your suggestion after going back to Dec 1st with system restore it did the trick?.
I find it to be strange that I had to go back so far, as yet I have not had chance to check what software changes I had made, but I will.
Once again many thanks for your help, and may be I can return the favour one day?.
Paul |
trevf Regular Visitor
Posted: Fri Jan 19, 2007 2:14 pm Post subject: |
Many thanks
Paul. | I had exactly this problem after reinstalling my PC. It happened because I was running Camera Manager before running POI Uploader for the first time. _________________ Garmin i3
Firmware 3.4 |
Posted: Fri Jan 19, 2007 7:19 pm Post subject: camera manager |
Hi Trevf,
Thanks for your help also, I cannot tell you the way it was done the first time round?.
Because I set it so far back it removed poi/camera manager software. And after reinstalling the above And running the software the same way as you it now apears to be fine. The reason I went so far back was to reinstall camera manager and start afresh asI could not find it in add/ remove programs or through its own uninstall.
Many Thanks
Paul3 |
