Pocket GPS World :: View topic - POI Limit? TT1
POI Limit? TT1
marbar2k
PostPosted: Tue Jan 16, 2007 9:46 am    Post subject: POI Limit? TT1 Reply with quote
I have a TT1 Europe V2. Is there a limit to how many POI's You can have?
I am running the maps off the original SD card, I loaded a number of POI's from here such as Asda, Tesci, McDonalds etc etc...........there was around 30 catergories. I then tried to load the speed zoned camera database. I tried to enable them on the menu but there was only about 5 of the POI's in the list.
I double checked on the card and they where all on there. I deleted them and added the by camera type DB and they where all there!
Is there a limit on how many POI i can have or am i doing something stupid
PostPosted: Tue Jan 16, 2007 11:35 am    Post subject: Reply with quote
For v6 software it should be 100 POI categories.
For v5 it was 39 (except for one version where it went down to 24!).
This excludes the built-in POI categories, which do not count towards the total.
Actual numbers of entries in each category is virtually limitless.
So you should be OK, even with the full speed-zoned set you are only looking at around 54 categories.
Something funny is going on....
You could try adding the camera files first (go on... try the "speed-zoned" set of 2, much more useful!).
If they are all working OK, then try adding the others one by one.
Scoobydooby
PostPosted: Wed Jan 17, 2007 3:49 pm    Post subject: Re: POI Limit? TT1 Reply with quote
marbar2k wrote:
....I then tried to load the speed zoned camera database. I tried to enable them on the menu but there was only about 5 of the POI's in the list.
There is a choice of camera files as a download from this site, one type contains 5 different types of camera for all speeds, another contains the same types but expanded out into the various limits 20,30,40---70 etc
Sounds like you may have possibly downloaded the wrong file, I think you wanted the speed zoned complete file.
Scoobs
Tom Tom Go 510 (new model)
I'd be lost without it !!
22.063 (19 Jun 24)
