Pocket GPS World :: View topic - TTONE-warn when near POI ?
acekiddy
PostPosted: Mon Jan 15, 2007 5:36 pm    Post subject: TTONE-warn when near POI ? Reply with quote
At the risk of ‘re-typing’ yourself can you please advise ?
Have just upgraded to TT ONE (original) App:6.520 with GB+ map
Copied the contents of the UK camera .zip into the GB+ folder
Have read somewhere that the speed camera icons no longer live in the ‘manage POI’ folder so how do I change the ‘warn when near POI’ distance and ‘warn on route’ checkbox ?
Have tried this solution :
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=18701
but this is for the ‘TT Go’ not ‘ONE’ (enable/disable POI is not an option)
thanks !
PostPosted: Mon Jan 15, 2007 5:48 pm    Post subject: Reply with quote
Camera files from this site work exactly the same as they always have:
the ov2 and matching bmp files go into your MAP folder (whatever it is called, it will be obvious, something like "Great_Britain-Map" or "Western-Europe").
This is also EXACTLY the same for ALL TomTom models (there IS an "enable/disable POI" somewhere in your One's menu - you may need to tap "show all menu options" to see it though.
Setting alert distances and sounds is done in Preferences / Manage POI / Warn when near. - same as it always was.
It is the TomTom supplied camera database that has changed.
It is now set up in the "Plus" menu, and you CANNOT change warning distance or sound.
22.063 (19 Jun 24)
