Pocket GPS World :: View topic - Tomtom go 710 POI Warner custom Voices
stu14t
PostPosted: Fri Jan 12, 2007 10:58 pm    Post subject: Tomtom go 710 POI Warner custom Voices Reply with quote
I have just upgraded from my PDA TT5 to a Go 710
Cool I thought, must get POI Warner as I found it invaluable with TT5.
Does anyone know how to set up the custom voices?
I have put 16kHz ogg files all over the system and it cannot find them. I am now loosing patience and will soon uninstall and ask for a refund if its not sorted soon
Can anyone help?
Tomtom GO 710 + TMC RDS
Ipaq 2210 6GB CF II Microdrive
TTN5 with Holux CR-100/ Globalsat 338 BT
PostPosted: Fri Jan 12, 2007 11:04 pm    Post subject: Reply with quote
For a start you should be using 22050Hz ogg files with that device, the ogg files need to go into the curent Active map folder (same place as you put the Speed Camera POI files) - #5 on THIS Page should give you a few pointers in the right direction, just use the inbuilt POI Warner the device has, why try loading something else? software inteneded for the PDA will not always work on the PNA units - Mike
stu14t
PostPosted: Sat Jan 13, 2007 12:24 am    Post subject: Reply with quote
I can't of made myself very clear.
I am using POI Warner software spesificly designed for Tomtom Gonot the pda version and I was instructed by the manufacturer of that software to use 16Khz mono files.
I just wonderd if anyone else was using this software and could point me in the right direction as the manufaturer navigating.de has very poor or no instructions.
PostPosted: Sat Jan 13, 2007 4:54 pm    Post subject: Reply with quote
If you mean returning the POIWarner software for a refund (in your original post it looked like you meant returning the TomTom!) then I think you should...
Quote (from http://www.navigating.de)
The POI-Warner is an add-on which complements your TomTom GO / ONE / RIDER with indispensable features.
As the name suggests, the Point-of-Interest-Warner visually warns you of POIs as you approach them. Speed cameras, petrol stations and kindergartens are only some examples for POIs.
There is nothing I can see that it does, which isn't available already on the Go straight out of the box!!
Icon integration on the navigation map
All POIs show up as you drive anyway(with the picture of Burger King if you really want it)
Enables the warning and display of speed cameras
TomToms already come with their own camera warnings, or the database from here is even better. They both "warn and display".
Ogg files don't need any extra software, just add them to the map folder (22050Hz and give them the same name as the POI category) and they work!
POI warner may have its uses, (automatic update/sync of POIs?) but nothing I would pay for, if you can do it all yourself!
22.054 (22 May 24)
