philai3 Lifetime Member
![](modules/Forums/images/avatars/41684663345898b3c5c102.jpg)
Joined: Oct 10, 2006 Posts: 71 Location: Manchester, UK
Posted: Fri Jan 12, 2007 12:35 pm Post subject: |
Ok, roll it back to 2.7; I've done this because of freezing/hang ups, although yours sounds more severe than my case. This will tell you if it's power supply or a software issue. _________________ Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010 |
Lester_Burnham Frequent Visitor
Posted: Fri Jan 12, 2007 12:41 pm Post subject: |
philai3 wrote: | Ok, roll it back to 2.7; I've done this because of freezing/hang ups, although yours sounds more severe than my case. This will tell you if it's power supply or a software issue. |
Too much effort have to mess around with easygps to save my favourites.
Without batteries suits - I suspect it will be perfectly stable like that, and I can live with longer acquisition times. Around 5 minutes is perfectly livable. 20-30 and I'd have to reconsider, though. |
Posted: Fri Jan 12, 2007 12:45 pm Post subject: |
I don't find EasyGPS much of a fag - it takes about 30 seconds to back up or restore my favourites from loading the program to finishing, and is surely well worth doing anyway. And, apart from the acquisition times, aren't you fed up with it crashing all the time? _________________ Garmin I3 October 2006
Renault Clio
Mazda MX5 2010 |
Posted: Fri Jan 12, 2007 12:50 pm Post subject: |
philai3 wrote: | I don't find EasyGPS much of a fag - it takes about 30 seconds to back up or restore my favourites from loading the program to finishing, and is surely well worth doing anyway. |
I'm not disagreeing with occasionally backing-up with easygps - but I'd have to do that, then mess around reverting to 2.7, then importing everything again.
philai3 wrote: | And, apart from the acquisition times, aren't you fed up with it crashing all the time? |
Well I'm speculating that it won't crash all the time with no batteries in - didn't to me. And it's not all the time, it's just once the batteries have been in a week or two.
As to why I'm not overly keen on reverting to 2.70, one of the "improvements" I've liked since 2.70 is the changes to the timing of the voice prompts.
So, ideally, if I was to revert, it would be to 2.82 - but that version had a bug in the grouping of POI categories - so there's not one ideal firmware version I'd choose to revert to.
It may sound an odd thing, but I'd rather just workaround a problem in 3.20 that I find acceptable, than revert and be disappointed in something else. |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Fri Jan 12, 2007 3:39 pm Post subject: |
lester , you haven't made it totaly clear whether you running with car charger and without internal battery's has solved your lock-up problem... _________________ *************************** |
swanson2 Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_ani_013.gif)
Joined: May 17, 2006 Posts: 59 Location: Sedgefield, County Durham
Posted: Fri Jan 12, 2007 3:44 pm Post subject: I prefer Dry Cells |
Hi Lester_Burnham,
As you rightly say I did mean "AA" batteries.
I prefer the "dry cells" to rechargeable because as well as lasting a long time, (I always use the 12v car power supply), it is easy to carry a spare set of batteries.
If rechargeables run down you normally have to take them home to reecharge them.
Hope you have sorted out your problem.
Robert swanson
:D _________________ I have enjoyed the past, but my main interest is in the future, because I am going to spend the rest of my life there! |
Posted: Fri Jan 12, 2007 3:47 pm Post subject: |
zogman wrote: | lester , you haven't made it totaly clear whether you running with car charger and without internal battery's has solved your lock-up problem... |
Well that's how I ran it today, and I had no lock-ups.
I heavily suspect it will, though, 'cos I firmly believe - and there's been other mention of it, here - that whilst running using the car charger, batteries when not fully charged have been known to cause issues and crashes. |
Posted: Fri Jan 12, 2007 4:02 pm Post subject: |
thats good news in a way i suppose, only time will tell now.. ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ *************************** |
Gez777 Occasional Visitor
Posted: Sun Feb 04, 2007 12:56 am Post subject: Constant Hanging with 3.20 on i3 |
Hi, I installed 3.20 on my i3 a few days ago and used it today on a trip to london on well charged Ni-Mh batterys (still showing 4 bars!) It constantly hung and stopped navagating several times, and said "trouble accuiring satellites" loads of times (on a motorbike???) It never did any of this on my old version (2.70 I think, but I didn't note it before upgrade) and I have done the same journey several times before now, with no problems.
Please can someone advise me how to revert back to 2.70, and where I can get the software? Many thanks. Gerry. |
