Pocket GPS World :: View topic - i3 crashing
i3 crashing
Goto page Previous  1, 2
philai3
PostPosted: Fri Jan 12, 2007 12:35 pm    Post subject: Reply with quote
Ok, roll it back to 2.7; I've done this because of freezing/hang ups, although yours sounds more severe than my case. This will tell you if it's power supply or a software issue.
Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010
Lester_Burnham
PostPosted: Fri Jan 12, 2007 12:41 pm    Post subject: Reply with quote
Too much effort have to mess around with easygps to save my favourites.
Without batteries suits - I suspect it will be perfectly stable like that, and I can live with longer acquisition times. Around 5 minutes is perfectly livable. 20-30 and I'd have to reconsider, though.
philai3
PostPosted: Fri Jan 12, 2007 12:45 pm    Post subject: Reply with quote
I don't find EasyGPS much of a fag - it takes about 30 seconds to back up or restore my favourites from loading the program to finishing, and is surely well worth doing anyway. And, apart from the acquisition times, aren't you fed up with it crashing all the time?
Renault Clio
Mazda MX5 2010
Lester_Burnham
PostPosted: Fri Jan 12, 2007 12:50 pm    Post subject: Reply with quote
I'm not disagreeing with occasionally backing-up with easygps - but I'd have to do that, then mess around reverting to 2.7, then importing everything again.
Well I'm speculating that it won't crash all the time with no batteries in - didn't to me. And it's not all the time, it's just once the batteries have been in a week or two.
As to why I'm not overly keen on reverting to 2.70, one of the "improvements" I've liked since 2.70 is the changes to the timing of the voice prompts.
So, ideally, if I was to revert, it would be to 2.82 - but that version had a bug in the grouping of POI categories - so there's not one ideal firmware version I'd choose to revert to.
It may sound an odd thing, but I'd rather just workaround a problem in 3.20 that I find acceptable, than revert and be disappointed in something else.
zogman
PostPosted: Fri Jan 12, 2007 3:39 pm    Post subject: Reply with quote
lester , you haven't made it totaly clear whether you running with car charger and without internal battery's has solved your lock-up problem...
swanson2
PostPosted: Fri Jan 12, 2007 3:44 pm    Post subject: I prefer Dry Cells Reply with quote
Hi Lester_Burnham,
As you rightly say I did mean "AA" batteries.
I prefer the "dry cells" to rechargeable because as well as lasting a long time, (I always use the 12v car power supply), it is easy to carry a spare set of batteries.
If rechargeables run down you normally have to take them home to reecharge them.
Hope you have sorted out your problem.
Robert swanson
:D
I have enjoyed the past, but my main interest is in the future, because I am going to spend the rest of my life there!
Lester_Burnham
PostPosted: Fri Jan 12, 2007 3:47 pm    Post subject: Reply with quote
Well that's how I ran it today, and I had no lock-ups.
I heavily suspect it will, though, 'cos I firmly believe - and there's been other mention of it, here - that whilst running using the car charger, batteries when not fully charged have been known to cause issues and crashes.
zogman
PostPosted: Fri Jan 12, 2007 4:02 pm    Post subject: Reply with quote
thats good news in a way i suppose, only time will tell now.. Wink
Gez777
PostPosted: Sun Feb 04, 2007 12:56 am    Post subject: Constant Hanging with 3.20 on i3 Reply with quote
Hi, I installed 3.20 on my i3 a few days ago and used it today on a trip to london on well charged Ni-Mh batterys (still showing 4 bars!) It constantly hung and stopped navagating several times, and said "trouble accuiring satellites" loads of times (on a motorbike???) It never did any of this on my old version (2.70 I think, but I didn't note it before upgrade) and I have done the same journey several times before now, with no problems.
Please can someone advise me how to revert back to 2.70, and where I can get the software? Many thanks. Gerry.
PaulB2005
PostPosted: Sun Feb 04, 2007 12:29 pm    Post subject: Reply with quote
Please don't double post - see the answer http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=46215&start=195
Page 2 of 2
