BoutTime Occasional Visitor
Posted: Mon Jan 08, 2007 10:05 pm Post subject: Where is the 'Hidden Menu' Hiding?? |
I've got a Nuvi 360T and I'm looking for the infamous Hidden Menu. Can anyone tell me how I access it? Do I need to be connected to external power and have the TMC Receiver connected?
Cheers |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Tue Jan 09, 2007 12:29 am Post subject: |
dunno about the hidden menu but you do need car battery or pc power to run the tmc.... _________________ *************************** |
Abakus Occasional Visitor
Posted: Tue Jan 09, 2007 8:59 am Post subject: |
as far as i know there are two, touch the upper right screen for more than 6 seconds or the lower left edge same length - answer is valid for 510 but nuvi maybe the same. |
Posted: Tue Jan 09, 2007 9:09 am Post subject: |
I use the following on my 310D tap the speed button lower left corner, this will take you to the trip menu, now press and hold (for about 10 seconds) the Overall Avg display, this will give you acess to where you want, scroll through the pages until you find the one you need. Please don't mess around with settings in here or you could damage the device - Mike |
Posted: Tue Jan 09, 2007 10:22 am Post subject: |
Cheers Fellas. I used Mikealder's method and it worked. I was just being nosy and wanted to have a look, although a little while ago when my Bluetooth wouldn't work, the Hidden Menu might have come in handy. You can update/re-install the Bluetooth within the Menu.
Thanks again |
swing Pocket GPS Verifier
Posted: Tue Jan 09, 2007 4:47 pm Post subject: |
BoutTime wrote: | You can update/re-install the Bluetooth within the Menu. | You can also cause problems to your unit (as Mike says), so it's important people are careful when in these menus. |
