TomDavison Lifetime Member
![](modules/Forums/images/avatars/gallery/simpsons10.jpg)
Joined: Mar 02, 2006 Posts: 384 Location: Bedford, England
Posted: Mon Jan 08, 2007 4:36 pm Post subject: Warnings on/off route. |
Is it possible to set up camera databases in two different map folders, and use different parameters for each. I have in mind using an up to date map with the cameras set to warn on route, for when I have routes set up, but using an old map with them set to warn at all times, for when I'm just driving around without a route set. That way, all I have to do is switch maps, instead of changing the "warn on route" for 25 different camera types. If I'm not using the old mapping for navigation, it doesn't matter if it's out of date - the POIs should still appear where they're supposed to. |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Mon Jan 08, 2007 4:38 pm Post subject: |
i think the 'warn on route' is a standard setting what ever map you use.... _________________ *************************** |
Andy_P Pocket GPS Moderator
Posted: Mon Jan 08, 2007 4:51 pm Post subject: |
Well I think it wouldn't be...
I've left my Go at home so can't try it for an hour or two. Can anyone else confirm either way? |
Posted: Mon Jan 08, 2007 4:52 pm Post subject: |
zogman wrote: | i think the 'warn on route' is a standard setting what ever map you use.... |
I think it is with the Tom Tom cameras, but with the PGPS database, when you activate each category, as well as options for sound and distance, you get a "warn on route" option. |
Posted: Mon Jan 08, 2007 6:52 pm Post subject: |
yes you're right tom, i forgot about that bit on each warning.... ![Embarassed](modules/Forums/images/smiles/icon_redface.gif) _________________ *************************** |
Posted: Tue Jan 09, 2007 3:33 am Post subject: |
Better late than never..
I just tried it and can confirm you are able to have "Warn only on route" set ON in one map and OFF in another. |
Posted: Tue Jan 09, 2007 9:32 am Post subject: |
So if you just drive around without warn on route set, and no route active, do you get speed camera warnings? |
Posted: Tue Jan 09, 2007 11:51 am Post subject: |
Yes
But you get them for adjacent roads etc. too ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Tue Jan 09, 2007 12:20 pm Post subject: |
like andy said you might be doing 70 mph on a motorway and then the tomtom will warn you of a speed limit of 30 mph on a road running parallel to the motorway.. _________________ *************************** |
stevejarvis Occasional Visitor
Posted: Tue Jan 09, 2007 3:10 pm Post subject: |
The real solution is for the warn on route setting to be ignored if there is no route, but I guess there is no way to make it do this. |
Posted: Tue Jan 09, 2007 5:25 pm Post subject: |
Andy_P2002 wrote: | Yes
True, but at least you don't have to activate all 25 categories if you want to use navigation without the false alarms. This would give a couple of clicks between the options of having only specific warnings when a route is being followed, but still have access to the camera warnings when you didn't need navigation. And if you haven't got a route set, you generally are happy to get warnings of local cameras anyway. It's no different from the early Road Angel that I had for a couple of years, which only gave proximity warnings to cameras, with no route filtering available. |
