Pocket GPS World :: View topic - Where is the 'Hidden Menu' Hiding??
BoutTime
PostPosted: Mon Jan 08, 2007 10:05 pm    Post subject: Where is the 'Hidden Menu' Hiding?? Reply with quote
I've got a Nuvi 360T and I'm looking for the infamous Hidden Menu. Can anyone tell me how I access it? Do I need to be connected to external power and have the TMC Receiver connected?
zogman
PostPosted: Tue Jan 09, 2007 12:29 am    Post subject: Reply with quote
dunno about the hidden menu but you do need car battery or pc power to run the tmc....
Abakus
PostPosted: Tue Jan 09, 2007 8:59 am    Post subject: Reply with quote
as far as i know there are two, touch the upper right screen for more than 6 seconds or the lower left edge same length - answer is valid for 510 but nuvi maybe the same.
PostPosted: Tue Jan 09, 2007 9:09 am    Post subject: Reply with quote
I use the following on my 310D tap the speed button lower left corner, this will take you to the trip menu, now press and hold (for about 10 seconds) the Overall Avg display, this will give you acess to where you want, scroll through the pages until you find the one you need. Please don't mess around with settings in here or you could damage the device - Mike
BoutTime
PostPosted: Tue Jan 09, 2007 10:22 am    Post subject: Reply with quote
Cheers Fellas. I used Mikealder's method and it worked. I was just being nosy and wanted to have a look, although a little while ago when my Bluetooth wouldn't work, the Hidden Menu might have come in handy. You can update/re-install the Bluetooth within the Menu.
Thanks again
swing
PostPosted: Tue Jan 09, 2007 4:47 pm    Post subject: Reply with quote
You can also cause problems to your unit (as Mike says), so it's important people are careful when in these menus.
23.015 (29 Jan 25)
