mrsilly Occasional Visitor
Posted: Fri Jan 05, 2007 2:09 pm Post subject: ITN by Lat/Long on Tom Tom unit. |
Hi, I'm off on a rally in Africa and have downloaded Off Road Navigator Which will show me the direction to a waypoint i enter. It does however support the standard TomTom Itn file but when i try and enter the lat/long of the waypoints they are off of the map so it won't accept them.
Is there anyway round this? I'd really like to be able to do it on the unit as the checkpoints sometimes change on the day i can't enter them before i go and i don't have a laptop to take to use other software.
[/url] |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Fri Jan 05, 2007 4:35 pm Post subject: |
Are you sure you entered the lat/lon in the right format for TomTom? You have to get the position in decimal degrees (not degrees minutes seconds or degress minutes.minutes) then multiply it by 100,000.
Add a minus sign if the position is South of the equator or West of the WGS84 meridian.
For example, N51.50793 W0.12807 would become 5150793 -12807
Good luck! _________________ Gone fishing! |
duckie008 Regular Visitor
Posted: Sat Jan 06, 2007 10:03 am Post subject: |
You are using a TomTom in Africa?? - Good Luck and don't get lost!
The UK maps are not even up-to-date, let alone Africa's!!!
Have a good time. |
Posted: Sat Jan 06, 2007 4:40 pm Post subject: |
Skippy wrote: |
Good luck! |
I tried your method but it does not accept it, it has to be N51.50793 W0.12807 format and must exist on a Tomtom map for it to be accepted. For example Dakar 14.34N 17.29W, try it for yourself. |
Posted: Sat Jan 06, 2007 4:41 pm Post subject: |
duckie008 wrote: | You are using a TomTom in Africa?? - Good Luck and don't get lost!
Have a good time. |
Not using TomTom as such, just the GPs receiver with the off road navigator software, this software just tells you which direction to drive and how far the waypoint is. |
46jimbo Regular Visitor
Posted: Sat Jan 06, 2007 9:36 pm Post subject: |
Thanks for the heads up, will try it. |
