T10HJS Occasional Visitor
Posted: Thu Jan 04, 2007 10:48 am Post subject: Nüvi 310 loaded the cameras but theres a problem? |
As above i have loaded the camera database i can see them on the map as verry small little grey dots with there info but i have to zoom right in to see them so i cant see them on normal size and i went to test and it didnt warn me i was approaching a camera. i have checked the POI settings its all set up to alert me at maximum proximity but is still not working can anyone please help me?
Thanks Steve |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Thu Jan 04, 2007 11:12 am Post subject: |
Which version of the PGPSW camera database did you download?
What settings did you use in POI Loader?
What happens if you go to Where To? Custom POIs - are the speed camera files there?
If they are on the map, then I would expect POI Loader, left in Express Mode to have set them up correctly, so let's look elsewhere for the problem:
What version of POI Loader do you have?
What is the firmware / software version of your Nuvi?
In Settings / Proximity Points / Alerts, what options do you have?
within that menu, press Audio, and again confirm the list of options and which one is selected? |
Posted: Thu Jan 04, 2007 2:00 pm Post subject: |
Thank you for your quick response.
i got the POI loader form the Garmin website, im not to sure on what settings i selected when loading them on i think i may of used express, is this a issue?
my Garmin 310 is running
SOFTWARE VERSION 3.30
In the where to i do not have a tab saying Custom POI's no sure why that is?
in Settings/Proximity Points/Alerts i have
-Custome POI'S
-Garmin Saftey Cameras
both ticked
in Audio i have
-Single Tone
-Continuos Speed Alerts
-Continuoes All Aletrs (selected)
I Downloaded the Garmin UK - Singel Filewith all cameras GPX
Thanks For Your help
Steve |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15158 Location: Bradford, West Yorkshire
Posted: Thu Jan 04, 2007 3:45 pm Post subject: |
hi, you'll be better off using the 'poi loader - i3 nuvi etc (consolidated by type)' or 'speed zoned (24 files)' downloads.
these will work correctly with poi loader and will add the 'custom pois' tab when installed with poi loader. it will also show the icons (not included with gpx)
MaFt |
Posted: Thu Jan 04, 2007 5:24 pm Post subject: |
thanks for your response i will try that |
Posted: Thu Jan 04, 2007 7:03 pm Post subject: |
As MaFt says, I think your problem was that you downloaded the wrong file, and so the camera data was not transferred to your unit in the first place. Any camera you are seeing are the Garmin database.
You may also find once you have loaded the PGPSW database that changing the Audio setting from Continuous All Alerts to Continuous Speed Alerts will help.
Your versions are fine by the way. |
