Pocket GPS World :: View topic - How do I upgrade SD Card for Tom tom one v2 and Tom Tom 510
kak85a
PostPosted: Wed Jan 03, 2007 11:03 am    Post subject: How do I upgrade SD Card for Tom tom one v2 and Tom Tom 510 Reply with quote
I have purchased a Sandisk 1gb and 2gb SD card and would like to know if anyone can advise how I upgrade both my Tom Toms. I tried copying all data from Tom Tom One disk to 2gb Sandisk but when I inserted into my TomTom One it advised I needed to take out and insert another disk presumably because it did not recognise the new one.
Any help would be really appreciated as I am a complete newby to this sort of thing.
Many Thanks
Karen
Eldar
PostPosted: Wed Jan 03, 2007 12:32 pm    Post subject: Reply with quote
Copy all the files from the original cards in two separate directories on your PC (make sure that the hidden files are shown), then copy them to the new cards.
kak85a
PostPosted: Wed Jan 03, 2007 1:21 pm    Post subject: Still have problems --help!! Reply with quote
I thought I would try the TomTom One V2 first. I have show all hidden files selected and have used select all from the root directory to copy all files to a folder. I then used the same process to copy from foleder to SD card. The files copy over no problem but when inserted into the TomTom One I get a picture with a cross through the disk and a pair of hands removing it. I have done this several times now with the same outcome.
Any other advice or is this a new problem with Tomtom One v2?
Karen
Eldar
PostPosted: Wed Jan 03, 2007 1:37 pm    Post subject: Reply with quote
Could you please list the files which you have on your new SD card
kak85a
PostPosted: Wed Jan 03, 2007 1:42 pm    Post subject: Thanks for your help Reply with quote
Is there a quick way of printing this or will I have to type out individually. Do you also want sub directories.
Karen
Eldar
PostPosted: Wed Jan 03, 2007 1:56 pm    Post subject: Reply with quote
programs - accessories - command prompt
then in the command prompt window type cd FullPathToTheSDcard
then type dir
include the sub-directories just in case
kak85a
PostPosted: Wed Jan 03, 2007 3:30 pm    Post subject: All Files now on New SD Disk that doesn't work Reply with quote
Hiya
I have finally got a listing of the filse on the new disk and have saved it as a txt file. When I try and copy and paste into a reply here it will not allow me to submit it says the html tags are not allowed.
How can I paste the list here for you?
Karen
kak85a
PostPosted: Wed Jan 03, 2007 4:28 pm    Post subject: Further thought Reply with quote
I could email to you
Eldar
PostPosted: Wed Jan 03, 2007 5:13 pm    Post subject: Re: Further thought Reply with quote
sure, go ahead
kak85a
PostPosted: Wed Jan 03, 2007 5:46 pm    Post subject: Email Reply with quote
Hi Could not mail via the private mail either so sent to contacts on your www site ref ELDAR. Hope that is OK.
Karen
Eldar
PostPosted: Wed Jan 03, 2007 6:00 pm    Post subject: Re: Email Reply with quote
Karen
yep, go through the website
Eldar
PostPosted: Wed Jan 03, 2007 6:07 pm    Post subject: Reply with quote
OK, got it. You seem to have all the necessary files there. All I can suggest is that you re-format your new card and copy only the following files onto it:
data.chk
system
ttsystem
voices
United_Kingdom_and_Republic_of_Ireland
kak85a
PostPosted: Thu Jan 04, 2007 9:58 am    Post subject: SD Card Problem Reply with quote
Hiya
Thanks for your reply did as you said and got exactly the same problem.
Karen
Eldar
PostPosted: Thu Jan 04, 2007 10:43 am    Post subject: Reply with quote
I've created a 510 SD for you - try re-formatting the card again and copy all the files from the archive I've sent to to you.
kak85a
PostPosted: Thu Jan 04, 2007 10:52 am    Post subject: 510 SD Files Reply with quote
Hiya
Thanks very much for this but I have not even attempted to upgrade the 510 yet. The one we have been looking at is the Tomtom One V2. Should I just give this one up as a bad job?
Many thanks
Karen
22.105 (30 Oct 24)
