Pocket GPS World :: View topic - Object not found !!!
mciortea
PostPosted: Tue Feb 10, 2004 12:47 am    Post subject: Object not found !!! Reply with quote
The Error I'm getting is
Object not Found
I'm behind a firewall, but I put in the correct proxy and I can check for updates no problem, so I know it works.
I also get the same problem at home where I'm not behind a firewall.
I'm trying to update the USA zip codes
Thank you
PostPosted: Tue Feb 10, 2004 9:05 am    Post subject: Reply with quote
POIEdit won't work through proxies unless you have a complete open socks connection (full access to go through a proxy).
I'd check the FAQ because if you don't have a proxy server all you need to do is reconfigure IE to work correctly (without proxy) and it will work.
Check the FAQ on how to configure IE and Proxies here.
