PAUL-R-S Occasional Visitor
Posted: Tue Jan 02, 2007 11:59 pm Post subject: version 6 map and POI warning sound |
ive just downloaded the new version 6 map for ttn5. after playing about a bit with a larger sd card. im not able to get the warning voice file for the speed cam POI to work.
anyone else had this problem or even a cure for it ? |
Space_Cowby Lifetime Member
Posted: Wed Jan 03, 2007 12:07 am Post subject: |
Have you looked at this post ? |
Posted: Wed Jan 03, 2007 12:36 am Post subject: |
i hadnt seen that. thanks for pointing that out |
aj2052 Frequent Visitor
Posted: Wed Jan 03, 2007 3:12 am Post subject: |
I updated my maps to v660, and had to reinstall my voices because they were in a new data.chk file that I had previously installed, when I updated my maps they had overwritten the new data.chk file, so had to replace and then everything back to normal, is this what happened to yours |
Posted: Wed Jan 03, 2007 4:47 am Post subject: |
Changing a map will not overwrite the data.chk file, but the upgrade to the actual software version does load a new data.chk file thereby wiping out your previously set spoken alerts file.
If you switch to using the ogg file method (as linked to above) this problem disapears, each time a new software version is released load it and your spoken POI warning files will still be in place - much less messing around - Mike |
Posted: Wed Jan 03, 2007 12:25 pm Post subject: |
Mike. Your maybe correct, If I remember I possibly also updated version at same time, memory also ages |
Posted: Wed Jan 03, 2007 6:15 pm Post subject: |
Perhaps I should re-iterate the point I was trying to make, if you use the data.chk method for spoken alerts you are limited to 15 alerts, and if/ when TomTom upgrade the software at some future point the new release will load a new data.chk wiping out you previously loaded file.
If you use the ogg file method there is only the 100 POI limit to consider (every POI could have a spoken alert), and a new software load wouldn’t wipe out your warnings, its easy to set-up and considerably less messing about in the longer term - Mike |
