leaskovski Occasional Visitor
Posted: Sun Dec 31, 2006 3:16 pm Post subject: iGO 2006 SE format request |
Hi Guys,
iGO 2006 SE is going through beta testing at the moment and it has now got speed camera warnings added. Is it possible to generate the format for this program as well??
Here is the format...
Quote: | SpeedCam Txt format:
Header:
X,Y,TYPE,SPEED,DIRTYPE,DIRECTION
Field Description
X | horizontal/longitude (E/W) coordinate
Y | vertical/latitude (N/S) coordinate
TYPE | Camera type:
| 1 - Static camera,
| 2 - Built in Traffic light,
| 3 - Camera checking passing through red light,
| 4 - Section camera,
| 5 - Mobile camera
SPEED | Speed limit
DIRTYPE | Camera direction type:
| 0 - all directions (full 360')
| 1 - one direction (see DIRECTION field)
| 2 - both directions (DIRECTION + the opposite direction)
DIRECTION| Camera angle degree (between 0 and 359, 0 - North, 90 - East, 180 - South, 270 - West)
for example:
X,Y,TYPE,SPEED,DirType,Direction
18.9429837,47.4521967,1,100,2,90
Comments:
- Field names are not case-sensitive
- The last 2 fields can be omitted from the file, in this case all cameras will check all directions
- File name can be anything
- it has to be under POI/speedcam folder
- extension has to be TXT
- multiple files supported |
Many Thanks! |
Posted: Thu Jan 04, 2007 1:19 pm Post subject: |
Can a mod change the title of this Thread to iGO 2006 SE Speed Cams please?
It would make more sense then. Thanks. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15388 Location: Bradford, West Yorkshire
Posted: Fri May 04, 2007 11:09 am Post subject: |
yes, that's easy enough to do. will try get something together later today (using heading & direction info etc) and will aim to have an official release with the next camera database release.
do you know what versions of igo this will work on? does it have to be, specifically, the 2006 se you mention?
MaFt |
linknet Frequent Visitor
Posted: Sat May 05, 2007 12:06 pm Post subject: |
MaFt wrote: | yes, that's easy enough to do. will try get something together later today (using heading & direction info etc) and will aim to have an official release with the next camera database release.
MaFt |
This works with the release version of "iGO 2006 SE" which has now been renamed by NavNGo as "iGO My way 2006 Plus".
Presumably it also works with most of the "iGO 2006 SE" Beta versions but these are now redundant following the release of the final version.
It does not work with the original "iGO 2006" version since this does not support speed cameras.
Regards
Roger |
alix776 Pocket GPS Moderator
Posted: Sat May 05, 2007 12:36 pm Post subject: |
as far as i know if the version iGO yuo have has a speedcam file in the POI file of the Igo image it should work (ready to be wrong..........yet again ) _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun May 06, 2007 11:55 pm Post subject: |
quick question: what's the difference between camera types 2 and 3?
MaFt |
Posted: Mon May 07, 2007 9:55 am Post subject: |
MaFt wrote: | quick question: what's the difference between camera types 2 and 3?
MaFt |
I asked this question on the Igo developers forum but received no reply.
However from what I can determine:
Camera Type 2:
This is a combined traffic light and speed camera, the icon shows both a speed camera and a traffic light symbol and the speed limit for the speed camera can be set.
I don't think that this type is used in the UK.
Camera Type 3:
This is a traffic light camera only, the icon shows only a traffic light symbol and there is no option to set the speed limit.
I think that this is the standard traffic light camera used to detect vehicles crossing the lights on red.
Regards
Roger |
Posted: Mon May 07, 2007 10:31 am Post subject: |
linknet wrote: |
Camera Type 2:
aka: RedSpeed - and yes, they ARE used here!
MaFt |
Posted: Mon May 07, 2007 10:48 am Post subject: |
MaFt wrote: | linknet wrote: |
Camera Type 2:
MaFt |
Do you differentiate between RedSpeed And RedLight cameras in the PGPSW database ?
Regards
Roger |
Posted: Mon May 07, 2007 11:28 am Post subject: |
yes and no - we keep a note of which are redspeed but at present they just get bundled with the redlight files
MaFt |
Posted: Mon May 07, 2007 12:17 pm Post subject: |
What about the DIRTYPE and DIRECTION fields for the various camera types, do you have any data for these ?
Or will you just be setting both fields to zero (or just omitting them) ?
Regards
Roger |
Posted: Mon May 07, 2007 12:58 pm Post subject: |
linknet wrote: | What about the DIRTYPE and DIRECTION fields for the various camera types, do you have any data for these ?
Regards
Roger |
we have them just only mio and drivesmart can use them at the moment (and igo) so we don't release stuff that the other systems can't use!
MaFt |
dnote Occasional Visitor
Posted: Fri Jul 17, 2009 4:49 pm Post subject: speedcam angle |
Hi Guys,
I inspected the binary spud files and discovered the speedcam angle is stored in just a single byte. However an angle can range from 0 to 359 and a byte can only store 0 to 255. Any idea how store high angle values? |
