Pocket GPS World :: View topic - Down loads HELP
Down loads HELP
Bazgreenwood
PostPosted: Mon Jan 01, 2007 11:30 pm    Post subject: Down loads HELP Reply with quote
:x I have followed the instructions and they download ok but will not open
any help pls
JockTamsonsBairn
PostPosted: Tue Jan 02, 2007 12:31 am    Post subject: Re: Down loads HELP Reply with quote
any help pls
What name has the downloaded file got? What error message are you getting?
Jock
PostPosted: Tue Jan 02, 2007 12:34 am    Post subject: Reply with quote
You don't "open", you "extract"! Smile
The download is a zip archive. Double click on it then select "Extract all files" on the left of the window that opens up.
NOTE where it says it will extract them to.
When finished you will have a bunch of files (I can't be more specific as you haven't said what SatNav brand you have, or which of the database options you have chosen).
Do not try to "open" these files (except you could look at the .bmp icon files if you like) as often they are a file format that Windows does not recognise or understand.
Just follow the installation instructions very carefully. Usually it involves copying the files from where they extracted to (select them all with the mouse, right click, select copy) and then pasting them into the map folder on your SatNav (browse to the correct folder, right click in the window, select paste).
You will probably have to go through a set-up process on the unit itself to have them show up on the navigation screen
Hope this sets you on the way! Smile Come back with any more problems if you have any, but please give us more information to go on. Laughing
Bazgreenwood
PostPosted: Tue Jan 02, 2007 12:50 am    Post subject: Reply with quote
I cant get extract message up all i get when i double click is open and save i am on windows 98 if that makes a diff Sad
PostPosted: Tue Jan 02, 2007 1:00 am    Post subject: Reply with quote
Ahh, yes it does. Sorry, I made a rash assumption that you'd be on XP.
The file is compresed with a program called WinZip. Windows XP has a version of it built in, but with earlier versions you have to install the program itself.
Do a Google search for it. If I remember correctly, the last time I looked, the website tried its best to get you to buy it, but there is a free demo version on there somewhere.
Hirvevarra
Banned
PostPosted: Tue Jan 02, 2007 1:05 am    Post subject: Reply with quote
UnZipThemAll
Try this
Bazgreenwood
PostPosted: Wed Jan 03, 2007 6:32 pm    Post subject: downloaded! Reply with quote
Thanks guys done it now and tried it out on navman works ok but uses black crosses as a marker is this normal or can you get proper icons i.e camera icons for gatsos ect
regards Baz :D
22.101 (03 Oct 24)
