Pocket GPS World :: View topic - Question On 3300 compatibility?
allyourbasekris
PostPosted: Mon Feb 09, 2004 2:27 am    Post subject: Question On 3300 compatibility? Reply with quote
Basically I'd like to ask the best and brightest here, if I can use this sleeve with a normal nav system. Like TomTom?
I've just ordered one, and suddenly thought, `What if it uses a proprietry system for it's data.` Hope someone can help me. Otherwise my bargain turned into a lemon
PostPosted: Mon Feb 09, 2004 4:07 am    Post subject: Reply with quote
Assuming that you install the appropriate driver for the jacket so it exposes it's "COM" port you should be able to use it with any other application (namely TomTom). Beware that it uses exotic settings for the NMEA stream: 57600 with update rate every two seconds.
Configuration GPS
Taux de transfert : 57600, 8, N, 1
Mise à jour : Toutes les 2 secondes
Message en sortie :
NMEA 0183 version 2.20,
GPGGA et GPRMC, 2s
GPGSA et GPSSV, 4s
allyourbasekris
PostPosted: Mon Feb 09, 2004 4:32 am    Post subject: Reply with quote
Thanks for the prompt response, hmmm, Well I'll soon tell you if it works or not in practice once I receive it. It's got to work slightly better than my old navman 3000 (45 mins lock on anyone).
allyourbasekris
PostPosted: Tue Feb 10, 2004 5:24 pm    Post subject: Reply with quote
Just received the unit, (Thank you total pda), It works fantastic, the only thing I had to do was change my gps driver settings to the 3000 series driver. I'm a happy bunnie. Lock times have gone from up to 45 mins (or not at all) to about ooooh 5 secs.
22.062 (12 Jun 24)
