Pocket GPS World :: View topic - Viewing recently added POI's??
nbg
PostPosted: Fri Dec 29, 2006 4:17 pm    Post subject: Viewing recently added POI's?? Reply with quote
OK, I know I'm missing something really obvious here, but I just can't get any new POI's to work Embarassed
Situation is new 910 out of the box, copied in the speed camera POI's (from PGPSW) and under manage POI's added custom 'warn near POI's', also updated to 6.522. That's all, no aditional POI's or beggering about (apart from trying to get an RDS/TMC sticky pile of cack to work) with the unit.
Mike was kind enough to email over the Classic FM POI's, dropped them in the western_and_central_europe folder on the 910, I can't find them at all via manage poi's or enable/disable POI's. I've also tried downloading a few general ones and copying them the the same folder on the tomtom, although I can see them from windows explorer on the unit, nothing is found via the 910 interface Sad
As I said, I'm sure I'm missing something obvious, would be ever so grateful if someone could point out the bleeding obvious to me Confused
Many thanks,
Matt.
PostPosted: Fri Dec 29, 2006 7:00 pm    Post subject: Reply with quote
Browse Map..
Options..
Tick Points of Interest.
PostPosted: Fri Dec 29, 2006 7:14 pm    Post subject: Reply with quote
Do as Dennis has suggested then hit the POI button (lower left) and a list of POI will appear, tick the boxes of the POI you require to be visible, the PGPSW cameras and the Classic FM should be in the list, although if you have setup the warn when near option for each camera category installed this function should work irrespective of enabled or not - Mike
nbg
PostPosted: Fri Dec 29, 2006 8:13 pm    Post subject: Reply with quote
Chaps,
I've just copied (OV2 and BMP files) the classic FM and a random other POI (ASDA), clicked on "Browse Map", clicked "options" made sure that "points of interest" is ticked, clicked on POI, neither classic FM or ASDA are in the list, also from route planning ASDA isn't listed under shops or shopping centers Confused
Any other ideas gratefully received!
Matt.
PostPosted: Fri Dec 29, 2006 8:48 pm    Post subject: Reply with quote
Sorry, I'm out of my depth now!!.
Just two things..
You haven't actually said whether or not you can see the pgpsw camera POIs in Browse map and Explorer?
Somebody somewhere says there's a limit to the number of POIs you can get in there. If you've also "tried a few other ones" (before ticking the POIs in Browse map) might you by any chance have overloaded it? Maybe delete them all with Explorer, then drag and drop again only one set. I only use the cameras myself, no other POIs, so I never have the overload.
PostPosted: Fri Dec 29, 2006 9:12 pm    Post subject: Reply with quote
Try the following:
Tap the screen and select Navigate To
Next select Point of Interest
Next select POI near you
Tap the right arrow (lower left icon)
From the list presented can you scroll down and find Asda or Classic FM?
if so select the POI category and it should present a list of POI locations relevant to the category selected
The limit for the POI categories using TomTom version 6 is 100 so I doubt this is an issue in this case unless you have loaded more than Classic and Asda? - Mike
nbg
PostPosted: Fri Dec 29, 2006 9:49 pm    Post subject: Reply with quote
DennisN wrote:
Just two things..
I can see them in explorer, but not browse map - we live fairly close, asda wasn't showing at longwell green or cribbs
I did copy some others in, but again, the tomtom couldn't find them and I delected them, so I'm sure it's not overloaded.
Thanks fort the suggestions anyway Dennis Smile
nbg
PostPosted: Fri Dec 29, 2006 9:54 pm    Post subject: Reply with quote
mikealder wrote:
Try the following:
I've just done that Mike, neither are listed.
Nope, apart from the speed camera's, that's all that's in the map folder Confused
I have tried downloading the POI's again in firefox in case IE7 curupted (SP?!) the files, still no new POI's available on the 910...............
PostPosted: Fri Dec 29, 2006 10:29 pm    Post subject: Reply with quote
How close is "fairly"? Meet up this weekend? I've just tested by downloading ASDA and they are showing on my 710 plain as plain.
nbg
PostPosted: Fri Dec 29, 2006 11:53 pm    Post subject: Reply with quote
Hey fella, as much as an offer that is, Mrs & I are heading off to London this weekend and spending Sunday (New Years Eve) night in the company of Kylie Laughing
PostPosted: Sat Dec 30, 2006 8:04 am    Post subject: Reply with quote
Say, why don't you go to a concert or something whilst you're there?
No problem, when you get back offer still stands if you're close enough.
PostPosted: Sat Dec 30, 2006 8:09 am    Post subject: Reply with quote
nbg wrote:
Nope, apart from the speed camera's, that's all that's in the map folder Confused .......
I would hope there are a few more files than just the speed cameras in a map folder? someone else had similar trouble yesterday with a new 910 please see HERE It could be that you need to zoom in to the map in order to see the POI.
When you mention Asda POI this should be a single POI category in its own right it will not be sub-listed under a different heading, it should appear in your POI list as Asda, the same applies to the Classic FM POI file.
I rolled my 910 back to out of the box configuration last night then updated it directly to 6,522, added the Classic and Asda POI files they both work fine, so the issue must be with your device, have you used it out on the road yet? and do the camera warnings work? - Mike
nbg
PostPosted: Tue Jan 02, 2007 11:11 am    Post subject: Reply with quote
Kylie was great, the concert was ok Laughing
nbg
PostPosted: Tue Jan 02, 2007 11:17 am    Post subject: Reply with quote
Aye, I just mean I've not added anything other than the speed camera files
They are not there on the map, I even pulled into the ASDA car park, it's deffo not there on the map.........
They are not listed.
I've done the same this morning, still no ASDA or classic FM, did manage to get ATM's working though....
I got it Christmas day and have done about 700 miles on the road with it since then, the camera warnings work perfectly, I'm just pulling out hair trying to get any other POI to work (other than ATM's it appears!) :x
Thanks for all your help Mike Smile
PostPosted: Tue Jan 02, 2007 1:05 pm    Post subject: Reply with quote
How close are you to Keynsham?
22.064 (26 Jun 24)
