Pocket GPS World :: View topic - does baud rate affect battery life of gps/ipaq
rob61280
PostPosted: Sun Feb 08, 2004 2:42 pm    Post subject: does baud rate affect battery life of gps/ipaq Reply with quote
Hi I was just wondering if anyone knows wether increasing the baud rate on my bluetooth gps reciever will reduce its battery life and/or my ipaqs battery life? also what affect does the baud rate have on accuracy etc?
thanks
Rob
HTC Wizard
GPSlim 236
PostPosted: Sun Feb 08, 2004 3:11 pm    Post subject: Reply with quote
It really won't impact much on the battery, but you also won't really see any improvement or issue with it.
Manufacturers usually set a default baud rate to which they are happy with. Most set this to 4800 although some set this to 38400 or 57600. The amount of data coming through the COM port at 4800 is very small indeed, so there is no bottleneck like for instance what you might see on a modem connected to a PC downloading a 2mb file. You can definately increase the baud rate, it just means that the small amount of data that comes through will come through a lot quicker. The GPS will just sit there waiting for the next stream of data. So really you won't see any difference. The positional information you get will be identical, likewise the time for fixes will be the same.
The only difference you will see is on the Navman sleeves where the GPS processor is in close proximity to the iPAQ processor. This can cause interference (RF Noise), so having a faster baud rate means that you get more time when the GPS isn't sending data to the Pocket PC which then helps cut down interference. This is the only time really when you will find it better having a higher baud rate.
rob61280
PostPosted: Sun Feb 08, 2004 3:32 pm    Post subject: thanks Reply with quote
thanks for the info dave, it was just one of those niggling things i had been wondering about
thanks again
HTC Wizard
GPSlim 236
PostPosted: Mon Feb 16, 2004 1:04 pm    Post subject: Reply with quote
I was just browsing your astronomy pages. Would dearly love a decent telescope but cannot justify the expense yet. Coincidentally I am from Llandudno, nice Aurora pictures, when were they taken?
22.062 (12 Jun 24)
